Dryer turn on, turns cloth but cloth do not dry.
Unplug the dryer and check the ignitor,the sensor and the thermal fuse located on the blower wheel housing,also if the dryer works correctly for the first 15 to 30 minutes then will not ignite again you have bad gas coils,also if the ignitor glows but flame doesn't lite most likely it's the coils,while your in there vac out the dryer,the duct where the lint filter slides into and if the vent line is long blow it out with a leaf blower
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
