Question about Sony VAIO VGN-CR220E/P Notebook
Screen will not work - Sony VAIO VGN-CR220E/P Notebook
  • George Bill
    George Bill Jul 04, 2010
    when, how long, details , you must put details, it's like saying car won't work, we don't know why unless you tell us what happened
  • raaghz Jul 04, 2010
    Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook. NOTES:
    Verify
    the correct Sony AC adapter is being used, and not a third-party
    replacement AC adapter. To determine the model number of the AC adapter
    for your computer, refer to the specifications available online through
    the Manuals/Specs/Warranty link on this page.
    Do not connect the AC adapter to a surge protector or extension cord.
    If the DC jack on the computer is loose or damaged, the computer may require service.
    Some
    AC adapters have a POWER LED indicator and can be confirmed as
    receiving power by ensuring the LED is lit. If the AC adapter is
    damaged, or the LED is not lit or continuously flickers when plugged
    into a working AC outlet, the adapter must be replaced. A replacement
    AC adapter can be obtained from the Sony® Parts and Accessories Sales
    Web site athttp://www.sony.com/pas or by calling (239) 768-7691.
    Attempt to turn on the computer normally.
    Press and hold the Power Switch for 5 seconds.
    Remove the battery.
    Disconnect the AC power adapter.
    Connect the AC power adapter.
    Attempt to turn on the computer. NOTE: If the computer turns on without the battery, connect and charge the battery for 24 hours.
    Disconnect all external devices that are connected to the computer. NOTES:
    These
    devices include, but are not limited to, a modem, floppy disk drive,
    network connection, USB device, printer, keyboard, or mouse.
    On
    older model computers, the maximum current output from the USB is
    500ma. If a connected USB device draws more current than this amount,
    the unit may not power on.
    Remove any additional Random Access Memory (RAM) that was installed in the computer.
    Attempt to turn on the computer. NOTES:
    The
    troubleshooting steps listed above should resolve your issue. If you
    have completed all of the steps and the issue is not resolved, service
    may be required.
    When shipping the computer for repair, include all notes of the LED status that display during troubleshooting. [[DAPC Direct Accessories and Parts Center]] if all the above troubleshooting steps fails, then you will have to ship the Computer to San Diego Service center
    Brigadier General:
  • 10,406 Answers
Take it to a darkened room, and turn it on.
Is there anything at all, although very-dim, on the screen? If so, the "inverter" has failed.
It's about a $20 part, but add $50 to $75 for a qualified technician to disassemble/replace/reassemble/test it.
Try connecting an external monitor, to see if the video-card can output as it should. If nothing, then replacing the motherboard (very expensive!) or replacing the computer is the next logical step.
If the external video is OK, then it's over $200 to buy a replacement LCD screen, plus $50 to $75 to do the replacement.
Posted on Jul 04, 2010
  • 162 Answers
  1. Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook. NOTES:
    • Verify the correct Sony AC adapter is being used, and not a third-party replacement AC adapter. To determine the model number of the AC adapter for your computer, refer to the specifications available online through the Manuals/Specs/Warranty link on this page.
    • Do not connect the AC adapter to a surge protector or extension cord.
    • If the DC jack on the computer is loose or damaged, the computer may require service.
    • Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged, or the LED is not lit or continuously flickers when plugged into a working AC outlet, the adapter must be replaced. A replacement AC adapter can be obtained from the Sony® Parts and Accessories Sales Web site at http://www.sony.com/pas or by calling (239) 768-7691.
  2. Attempt to turn on the computer normally.
  3. Press and hold the Power Switch for 5 seconds.
  4. Remove the battery.
  5. Disconnect the AC power adapter.
  6. Press and hold the Power Switch for 5 seconds.
  7. Connect the AC power adapter.
  8. Attempt to turn on the computer. NOTE: If the computer turns on without the battery, connect and charge the battery for 24 hours.
  9. Disconnect all external devices that are connected to the computer. NOTES:
    • These devices include, but are not limited to, a modem, floppy disk drive, network connection, USB device, printer, keyboard, or mouse.
    • On older model computers, the maximum current output from the USB is 500ma. If a connected USB device draws more current than this amount, the unit may not power on.
  10. Attempt to turn on the computer.
  11. Remove any additional Random Access Memory (RAM) that was installed in the computer.
  12. Attempt to turn on the computer. NOTES:
    • The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
    • When shipping the computer for repair, include all notes of the LED status that display during troubleshooting.
[[DAPC Direct Accessories and Parts Center]] If all the above troubleshooting steps fails, then you will have to ship the Computer to San Diego Service Center.
SOURCE:
I have a samsung f480 i but the screen is damaged on one side, but still works..... can i replace it with a normal f480 screen ? i have done so but the screen does not work ?
dear , if your screen still working after one side damaged , so thats great , but unfortuntly , its not work for more days . one day it i will damaged the whole screen ,so my suggestion is that.. purchase branded screen and replace the screen...
Jul 22, 2011 | Cell Phones
Touch screen not working
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
  5. Then follow the on screen instructions.
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
My lg ks360 phone screen not working
hey i have a lg ks360 and the screen just comes up with a black screen
Apr 11, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Touch screen stopped working
my touch screen stoped working i can still use all keys also i feel vibrate when touch the screen
helppp
Mar 07, 2010 | Samsung Tocco Ultra Cell Phone
Bb 9530 work well but screen does'nt work i have change the new screen but the problem still persist i have install os 4.7.0.148 the problem with my screen is black
If the problem persist even after changing the display then issue may be with the strip(which connects the display screen and the board).
Regards, Kesav
Mar 01, 2010 | RIM BlackBerry Storm 9530 Smartphone
My tv has sound but no picture except for a blue screen
My television worked this morning and now only shows a blue screen. The sound works but no picture except for a wavy blue screen.
Jan 22, 2010 | Televison & Video
About my Compaq Evo N800v Notebook PC laptop screen problem
My laptop is not working in the proper manner.Because for the screen the belt is may be some loose contact.some times the screen is shaking at the time of booting and immediately hanged.Then system is not working.Some times if we press upon the screen then it will work in good manner.If we remove the pressing hand,immediately the screen shakes and hanged the contents immediately.
Apr 06, 2009 | Compaq Evo N800v Notebook
take the battery off for 15 seconds and try to put it back again. goodluck
Dec 22, 2007 | T-Mobile Wing™ Smartphone
Sony VAIO VGN-CR220E/P Notebook Logo
184 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
