SOURCE: Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
SOURCE: Wii Remotes will not resync after using friends Fit Board
there is a flap in the wii open it up. open the spot where the batteries go on the controller. the controller and the wii should have a orange butten press them both at the same time.
SOURCE: remote not talking to console
If your remote is giving out and not allowing you to continue , then yes it could be bad..
But, its hard to tell since you just got the system and the new remote is already bad?
If its not staying in sync, then I would try a different remote before thinking any repair options
SOURCE: I can't access the wii shop channel, the consol
Hello :
Read this detailed article please: Wii Shop Channel .
I hope that will help .
rate please !
Testimonial: "Thanks! Good link info. "
SOURCE: We recently had a power
From the symptoms mentioned it seems that your Wii PSU is still not working OK.
If you have noticed the connector pin of the Wii PSU it has a lot of pins. It means the unit is supplying different voltages to the Wii game console. In the power outrage partial damage must have occurred to the PSU so some of the control voltage going to the Wii console must be low . The only way to confirm is to connect another Power Supply Unit before you jump to any conclusions . The important thing is do not change settings or you will get confused as to what the problem is caused by.
