My cd drive wasnt reading any cd roms. it seems like the cd drive trys too read the cd twice then gives up.i bought a new cd drom drive and the problem still happens.
The CD rom is limited to CD's. In order to read a DVD, you will need to install a DVD rom. My suggestion is to get an external DVD Burner - i just bought a Samsung slim external DVD burner that reads / writes CD's and DVD's.
You will have no luck ever reading a dvd in a cd rom.
CD/DVD ROM drives like yours employs two lasers to work properly, one for CD read function and the other for DVD read function.
It seems that your laser for DVD reading is either dirty or damaged.
Try an optical drive cleaner, if that does not fix it, you are going to have to replace the drive. If you have warranty then replace it or have it
fixed. However, if your warranty has expired then the best thing to do is
to buy a new one. They are not expensive these days so the price
difference between fixing it and buying new should not be huge.
A lens cleaner disk should be available from most computer shops.
I assume you have proper software for DVD video playback like PowerDVD, VLC media player etc.
my acer 4520 cd rom is not working well when i press cd roms butten its not *** out & also in my computer its tht cd rom icon is not showing so plz give me the solution asap....
the same problem of mine is my drive cannot able to read DVD then i make the solution if you have CD RAM/ROM + DVD ROM then change it to CD/DVD RAM because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
You Know i had also this type of problem but i solve it i buy a new CD/DVD RAM if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
1.some times this happened the loose connection of the IDE cable,and power cable. 2.so disconnect the IDE and power cables and then connect again. if not fix 3. exchange the IDE cable of hard disc. 4.if no result,the lens of CD Rom has damaged, you will be have to buy a new CD rom.... thanks!
the cd you inserted was not compatible with your cd rom. inorder to read all cds you must use cd roms that supports up 60x speed your only have 24x speed thats y it cant read cds that has above 24x.
