Have you had problems with enabling FancyUrls in your CMS (Content Management System)? A lot of hosts don't have mod_rewrite enabled, or even a basic .htaccess file. This simple fix is just clearly written to help users better understand what to do, as well as an easy copy/paste job.
Simply copy and paste this code into a new Windows notepad file.
"Save file as.." .htaccess - including the dot in front of htaccess.
Upload the file to your public_html directory, overwriting the previous one if any.
(Not a required step, use only if temp.htaccess exists.) If there is one called temp.htaccess, simply delete that one OR rename it as .htaccess and upload the new .htaccess for an overwrite. Copy the text below this line.. AddDefaultCharset UTF-8 Options +FollowSymlinks RewriteEngine on RewriteBase / RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule /?([A-Za-z0-9-]+)/? $index.php?id=$1 # Add a ReWriteBase line to any directory or subdirectory requiring it. # The default directory is "/", which is the root or main directory you use. ------------------------------------End copy Good luck to you!
A content management system enables you to maintain the content on your website without any additional software our technical skill. When using a CMS, you can add new pages, upload images and be in full control of your site - all you need is a web browser and an internet connection..Try this singapore web design company Singapore Web Design Development Company Singapore
Depends on your level of experience. The easiest thing to do is to use a content management system. When you sign up for a web host, many of them have installable CMS systems. However, you are limited somewhat by the parameters of the CMS system. For a basic website though, this will probably best suit your needs. Mambo is a very popular system
