I did not use it for last 6-8 months.
JVC Everio GZ-MG130U
OK, you did not use it for last 6-8 months, let me know what is the problem with this camcorder.
Thanks.
when i turn it on the minitor is blank
sorry screen monitor
Right, camcorder does not show you live image to record it but it shows on-screen display icons like tape remaining info, battery info etc.
If that is the symptom then it is ccd iamger chip failure problem and ccd imager chip will be replaced to get live view in camera mode for recording.
Please take camcorder to your local camera repair shop for ccd imager chip replacement to fix the issue.
Thanks.
If symptoms are different then give me little detail to diagnose the problem correctly.
NO it is NOT showing me anything. the screen is BLACK. it is NOT showing me display icons like tape remaining info, battery info etc. that you mentioned.
i am not sure what extra information you want me to give, the probelm might me very minor but i am not able to understand.
OK, just delete ccd imager chip failure information.
Your update changed the problem scenario, there is connecting flexible ribbon wire between lcd circuit board and camcorder main circuit board, this wire is broken that is why lcd board is not getting power/ signal from camera main board and its black/ blank.
Connecting flexible ribbon wire will be replaced to solve the issue. Local camera repair shop will do the job for you.
Thanks.
can you please suggest which Shop can take care of this issue? You mean i need to get the "new" wire that is going from battery to the camcoder right?
right?
No, not that wire that going from battery to camcorder.
Below image will give you better idea about where is that flexible wire located in camcorder.
Regarding local repair shop, I have no idea about your location so click Fixya Repair Directory and put your zip code, city name in "location" bar at left side to search out nearest camera repair shop in your area.
Thanks.
Flexible wire is located inside camera and above image is just for info to give you location idea.
I have one silly question. i have this big block of battory attached to the camera with wire going from battery to camcorder. i have to leave it as is right? And this wire you are talking about i do not see it but may be its connected internally! how much that would cost? any idea?
Yes, that wire is connected internally and camera will take apart to replace it.
It will cost you approx $40 plus labor.
Thank you very much welcomejee
