2002 Honda CBR 600 F(4)i Logo
Posted on Jul 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i replace a air filter on my honda cbr 600f
How do i replace the standard air filter on my honda cbr 600f 02 with a k&n
Anonymous
Level 3:
  • Master 518 Answers
  • Posted on Jul 03, 2010
Anonymous
Master
Level 3:
Answers
518
Questions
0
Helped
184203
Points
1302
It depends on the diameter of the carb inlet,the space between the carb and frame ,will the new filter fitting match up to the carb dia,
Spluttering at low revs
Specifications
The 1991 Honda CBR 1000F uses an in-line four cylinder, four-stroke engine that produces 36.5 cubic-inches of displacement. The engine uses a dual overhead camshaft system and has four valves per cylinder. The maximum power of the CBR 1000F is 93 horsepower at 11,000 rpm and the max torque is 45 ft-lb at 8,500 rpm. The motorcycle's compression ratio is11.3:1 while the bore by stroke ratio is 2.5 by 1.9 inches. The engine is liquid cooled. The transmission is a six speed and is chain driven. The top speed of the CBR 600F is 141 mph.
Dimensions and Features
The overall weight of the 1990 Honda CBR 600F is 460 pounds. The total fuel capacity is 4.36 gallons. The seat height is 32 inches, and the wheelbase is 55 inches. The front tire dimensions are 110/80-17 and the rear tire dimensions are 130/80-17. The front brakes are dual 276mm piston caliper disc brakes while the rear brake is a single 220mm pistol caliper disc brake. The suspension system uses a mono-shock swing arm design. The power to weight ratio is .44 hp/kg. This bike can go 0 to 60 mph in 3.8 seconds.
Appearance and Design
The 1990 Honda CBR 600F features a compact design. Close side mirrors flank a compact instrument panel and tight handlebars. This motorcycle sports a partial fairing that is designed for better aerodynamics. To reduce wind resistance, the legs and feet are fully positioned behind the motorcycle body. Like most sport bikes, when riding at fast speeds, the rider is intended to lie across the fuel tank to reduce drag. No chrome is visible on the bike, as the motorcycle body fully covers the chassis. The display panel features three gauges: a speedometer with built in odometer, a tachometer and a fuel gauge. The 1990 Honda CBR 600F is produced in various combination colors, including white, blue and red or black, purple and orange.
Could you tell what coolant i need for my cbr 600f 1994 model
Anything that says "Tested and proven non-corrosive on even the most exotic metals". You can't go wrong with Honda Products.
2helpful
2answers
Hey, 93 CBR 600F where's the air box
I am not entirely sure on that model.
Best bet would be under the gastank.
Wish I could be of more assistance.
2000 cbr 600f cutting out after 2-3 mile
buddy i had this problem once and i found the float was bent one side was lower than the over have a look if its not lower the float a tad by bending the metal the little needlt valve is on
1helpful
2answers
Keeps blowing the ignition/starter fuse and dies immediately
http://www.americanthunderbike.org/techtips/blownfuse.php
1helpful
Where can i get cbr 600f discs?
Google " Honda motorcycle brake discs CBR 600 " You should fine some there. It looks very promising. $20 on an Ebay listing noted in the listings.
Pleas rate this answer. Thanks markd5! :)
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
