Nokia 1600 Cellular Phone Logo
Posted on Jul 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Says insert sim
My nokia cell automatically says insert sim which had nothing any damage ............
Lebanon Raingam
Level 3:
  • Nokia Master 4,737 Answers
  • Posted on Jul 03, 2010
Lebanon Raingam
Nokia Master
Level 3:
Answers
4737
Questions
Helped
1385128
Points
16345
Before you do anything with it, please clean the sim card and sim card connector on the handset. Even a small rust/dust can create this problem.
If it doesn't help, you need to check the Sim card on another Handset. In most cases, this is damaged sim connector, and will be necessary to replace or re-soldered/refreshed. Sometimes even sim IC is the culprit which you need to replace or play jumper tricks. I would suggest you to get it done from a service center or from a nokia mobile repairing center.
Good luck.
Thanks for using FixYa.
4helpful
2answers
My nokia says no sim card and stuck again again
rijamunir, make sure if sim connector is not damaged, and try hard reset 3+*+green button+poer on button press and hold until show insert sim card. then insert sim card , the problem will be solved with hard reset described aboove.
Nokia 7230 is shutting down when a sim card insert
Hi.Is your sim card is OK ? Before you contact mobile repairing shop try to insert other sim card.Sometimes if the chip inside the sim card is damage the similar problem happened.Good luck.Thanks for visiting fixya
3helpful
2answers
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Honb'le sir I purchases a nokia 5800musicxpress from south korea. but i use it bangladesh. the mobile show offline my phone IMEI 359339037461968. p/z give me suggestion.
There can be two problems.
First, you might have put your phone in offline mode. Press the power button once. It will show list of profiles like Normal, silent, outdoor etc. Press Normal and your phone will search for network automatically.
Second, Your sim may be damaged. Please check by inserting another sim and see if it works.
Lastly, if nothing works, you may need to contact the service center.
2helpful
3answers
My Nokia 3220 show insert sim card but i already insert sim card
Check to make sure its not Backward...
2. Check the Sim card it self for damage the contact terminals should not be scratched or touching one another
May 09, 2011 • Nokia 3220
13helpful
4answers
Nokia 2730 insert sim
your sim card is damaged or the phone is locked to another network.if it worked previously it is a software or maybe hardware related bug, and need the intervention of a profesional.
1helpful
3answers
Nokai 6681 isgone to offline mode.
Hey Friend,
  • your SIM ic Damaged
  • Need to replace
  • Or Sim tray Damaged
  • OR sim not Properly inserted..
Is this Helped you.....
Rate me...
Thanks for Using FixYa
Insert sim problem 1100,1600
sometimes it is as simple as cleaning the sim card and sim points on the phone with a pencil eraser. sometimes it is related to a simcard IC (usually placed close to the sim tray in the phone) so if u do not succeed cleaning the sim and sim points of the phone u need to change the simcard IC
2helpful
Showing insert sim even if sim is inserted
the problem can be either of two
  1. your SIM has damaged maybe the golden strip behind SIM has got in contact with any magnetic material or scratched.
  2. your phones SIM reader has become unusable get it repaired at very low cost.
  3. pls rate me
  4. thank you
Nokia 1112 reboots quite often, and prompts ' Insert SIM'
1112 nokia shows local mode written on the screen nothing else itseems to be a hardware problem plz tell me the soloution
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
