Question about Kirby Ultimate G Bagged Upright Vacuum
The auto drive doesnt work. The lever even fell off the back.
At first, the lever to switch from neutral to drive was stuck in neutral - lo help with pushing the vacuum. Then the mechanism came off of the back of the vacuum. Is this something mu husband should be able to fix? Can you please point us in the right direction? If there are not directions for doing this online, what will it cost us to get this fixed?
    New Friend:
  • 110 Answers
Its not a simple fix, it will involve some disassembly of the motor unit, especially if the mechanism would not change from neutral to drive. One of the vac experts at vacuumland.org, a collector and enthusiast website, may be able to provide detailed instructions with pictures.
Posted on Nov 28, 2017
SOURCE:
SOURCE: Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Posted on Jul 16, 2007
RockyNR1
  • 324 Answers
SOURCE: Drive/Neutral lever fell off Kirby G5
Manual on how to do it - take a look HERE
Posted on Dec 02, 2008
b0sslady2001
  • 357 Answers
Please check out my brand new FREE online guide for this repair......
http://reviews.ebay.com/REPLACING-OR-REPAIRING-KIRBY-VACUUM-NEUTRAL-DRIVE-PEDAL_W0QQugidZ10000000011180003
HOPE IT HELPS!!!
Marci
Posted on Mar 17, 2009
  • 75 Answers
SOURCE: kirby neutral/drive pedal
just go to your local kirby vacuum shop or a vacuum shop.they can help you.
Posted on Jun 29, 2009
  • 240 Answers
SOURCE: How do you replace the drive/neutral lever (foot
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Posted on Mar 28, 2011
My G7D kirby vac was accidently dropped and the D & N lever came out of the machine. When I put the lever back in the hole it belongs in it is very loose and it doesn't switch from D or N.
The drive/ neutral pedal assembly must be replaced. This part is pressed together and cannot be repaired. A new assembly is about $17-$20. The power drive unit must be removed from the machine.
Jan 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Not picking up well, what are the N/D buttons on back for?
The N/D on the back is for the toe touch lever there and it stands for Neutral / Drive. When unit is on place the lever (push down) in the D position and it is a clutch assist to make it push easier. When unit is off, place in the N position to release the clutch and roll it around. Usually the plugs occur where the bag attaches the unit, disconnect bag and check there. Also insure the roller brush is working.
Nov 02, 2010 | Kirby Ultimate G Bagged Upright Vacuum
THE NEUTRAL/DRIVE LEVER HAS COME AWAY FROM THE HOOVER AND SOME OF THE INSIDES HAVE ALSO COME AWAY. I WOULD LIKE TO KNOW HOW TO PUT IT ALL BACK TOGETHER
I dismantled the cover, withdrew the gear drive assembly and found the bits that had come loose. The mechanism that selects neutral or drive had come away from its shaft. I simply put it all back together and tightened everything back up. Works a dream again.
Jan 10, 2010 | Kirby Heritage II Vacuum
Lever & belt placement in Kenmore Progressive upright vacuum
You are correct. The belt is supposed to go around the peg that is connected to the lever so that when it is on the Floor /Tools setting the belt is not driven by the drive shaft.
Dec 05, 2009 | Kenmore Vacuums
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
My Kirby 2000 will not turn on?
No power is usually when there is nothing installed on the front or bag is improperly installed. There are 2 safety switches that must be pressed in order for Kirby vacuum to work. So make sure you have the nozzle on the front and when installing bag assembly - push the plastic bottom part to the vacuum as far as it can go.
Nov 16, 2008 | Kirby G6 Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
298 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
