The door handle has come appart. How does the oven facing come off?
I'm not mechanically-inclined, but the frustration of an oven handle hanging by one side prompted me to try to become mechanical. Remove the entire door from the oven by working the hinges. Then put it on a flat surface (I used a pool table) and let the hinges act as a shim. Remove the bolts from the bottom edge and lift out the main panel and the end flanges. Carefully set the glass aside and it's an opportune time to clean it. You'll see two bolts which hold the door handle assembly in-place. Upon removing those, you'll finally be able to get at those interior door handle bolts. One of mine was missing a lock washer. I found adequate replacement parts and then reversed the process to re-assemble the door and place it back on the oven. This seems to be a common defect with this model, and it's unfortunate that the handle's bolts can't be assessed more easily, but when you go at it systematically, it wasn't as difficult as I had feared.
