Hi MY nanes Paul, I have a JCB m25 strimmer and bush cutter the cut off switch is inopperable, I have to stall the motor to stop are there outlets that will sell me a spare cut off switch, thanks
SPARK PLUG REPLACEMENT
See Figure 9.
This engine uses a Champion RCJ-6Y or NGK BPMR7A spark plug with 0.05 in.
electrode gap. Use an exact model and replace annually.
That gap is too big.... so looked for another and found it in metric. SPARK PLUG REPLACEMENT See Figure 12. This engine uses a Champion RCJ-6Y or equivalent spark plug with 0.63 mm electrode gap. Use an exact model and replace annually.a
Now 0.63mm is 0.025 inches... that's more reasonable.
TO MIX THE FUELSee Figure 3.? The product is powered by a 2-stroke engine and requires pre-mixing petrol with2-stroke oil. Pre-mix unleaded petrol and 2-stroke engine oil in a clean containerapproved for petrol.? The engine is certified to operate on unleaded petrol intended for automotive usewith an octane rating of 91 ([R+M]/2) or higher.? Do not use any type of pre-mixed petrol/oil from fuel service stations, such asthe pre-mixed petrol/oil intended for use in mopeds, motorcycles, etc. Do not useautomotive oil or 2-stroke outboard oil.? Use only synthetic 2-stroke oil.? Mix 2% of synthetic 2-stroke oil into the petrol. This is a 50:1 ratio
it is a petrol engine and the carby listed indicates that it is a 2 stroke
the oil /fuel mix ratio is 50:1 with a fuel octane rating of 91 ( do not use e-mix fuels ) recommended oil from the manufacturer specifications is a synthetic 2 stroke oil
Brand of manufactured oil optional
Dec 25, 2008 - how to reset the service light on a JCB JS 130 Excavator Hi I have serviced our JCB JS 130 ... my self and I am woundering if there is away of switching off the service warning light ... Helpful 41; Not Helpful; 1 Comment; Flag ... Posted on Feb 18, 2009 ... What kind of brake fluid goes into a jcb 3cx 1985/86?
Man, you have a problem!! Try ebay or a used machine breakers yard for a used harness. There are dvd's available for the JCB range covering parts but you may get one for wiring. Try the JCB owners forums for help
40:1. Which works out at 25mls of oil to every litre of petrol. Found the above answer on another site, 40:1 in the U.S. is 2.6 oz. of 2 cycle oil to 1 gallon of gas.
If I talk about India than I can suggest to you a good amount of JCB Spare Parts Manufactures and You can deal all parts Related to JCB And Backhoe Spare parts also Order From Here.
How do I wrap new wire on my m25 strimmer without it keep coming off
