Frigidaire FEF352 Electric Kitchen Range Logo
Posted on Jul 01, 2017
Lock on oven door
My mother-in-law has a Gibson self-cleaning oven, electric range, a few years old. The oven "Lock" light is flashing, like it is waiting to go into the cleaning cycle, and the latch on the oven door is stuck out causing the oven door not to shut. How do I get the light to go off and the latch to go back where it should be so the oven door can shut tight? Thanks for any help you can give regarding this problem.
M Anderson
5 Related Answers
Anonymous
  • 68 Answers
  • Posted on Apr 29, 2009
SOURCE: my frigidaire self cleaning electric stovetop
try to disconnect power to the unit for a few minutes the plug it back in. this may clear any errors with the control board and allow the door lock to reset as well. If this does not do the trick then i would have to check the door lock motor, the switches for the doorlock mechanism and also check to see if the control board is sending power down to the door lock motor.
Does the oven light switch work? hold the button in and see if the door lock moves.
Did this occur after you ran a self-clean cycle?
Anonymous
  • 473 Answers
  • Posted on Nov 12, 2007
SOURCE: Whirlpool Model RF376LXBN Range
What fault code is it giving you?
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 13, 2008
SOURCE: Door sags open when hot.
i just had this problem with a jenn air range i was repairing, installed new hinges door closed fine, heated oven hit 200 degrees and light came on (door opened slightly) as per techline I shimmed the hinge reciever to make a bit tighter. sure enough!!! been 3 weeks she hasnt called back yet (and trust me if it didnt work she would!.. call the tech back and have him call the tech line while in home
Anonymous
  • 1314 Answers
  • Posted on Sep 09, 2008
SOURCE: Fridgdaire self cleaning latch
try holding in on the door latch plunger the one that turns the oven light off when you close the door then press start then cancel and inspect the door plunger for any damage
Anonymous
  • 2920 Answers
  • Posted on Feb 04, 2009
SOURCE: self cleaning oven door lock is stuck and buzzing
you can still use the oven i would gt someone out as soon as you can to get the lock released but yes you can still use the oven
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
My frigidaire self cleaning electric stovetop range lock is on and i cannot close the door. the door light contiues to blink and i cannot bake or use the oven and i cannot clean my oven. Please help....
3helpful
2answers
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
After using my electric range self cleaning oven an f90err appeared and the door will not open. I would really like to cook my new years dinner .Can you help please ?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
2helpful
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
2answers
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
2answers
Oven shuts down
My mother-in-law's oven was doing the same thing. At first it was actually turning completely off which led me to think it was a loose connection on the circuit board. That turned out to be exactly what it was. I had to dismantle the front of the oven, remove the circuit board, and resolder the connections. The first time I did this I must have missed a few bad joints and that's when it started doing what you described (shuting off and showing lock door). I pulled it back apart and found a few more bad solder joints which I fixed; so far so good. This is of course one of those "don't try this at home" fixes but it least lets you know what is causing the problem.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
