GPS Logo
Posted on Jul 02, 2010
States that map updates are available but will not do anything when I press okay. It freezes up.
FIKRET UNALIR
Level 1:
  • Contributor 239 Answers
  • Posted on Jul 02, 2010
FIKRET UNALIR
Contributor
Level 1:
Answers
239
Questions
0
Helped
65951
Points
5
Generally you need to contact your GPS with internet. It generally leads you to pay with your credit card to continue for upgrading or whatever else. So it only reminds you to contact with the manufacturer. As a result you buy the product they offer.
  • dscusnret Jul 02, 2010
    what could be causing the freezing?
  • FIKRET UNALIR
    FIKRET UNALIR Jul 02, 2010
    There is no reply mechanism so it causes freezing.
Tomtom xxl problems
these have major issues during updates. mine also failed after update in very similar fashion. and after searching a lot of forums apparently its a very common thing. unfortunally i never found any solution to this. and ended up having to throw it away since it was past its warranty period. i suspect it was a buildt-in planned obsolescence since it was very rarely used (less than 6 times) but maintained at ideal long term storage condition
Jul 06, 2017 • GPS
I updated my garmin nuvi255 and it only shows usa maps, now I lost all of Canada
When you update the unit you are given selections based upon how much memory is available on your unit. With each map release, the map sizes become larger. On the 2xx series, you may not have had enough memory to have both the US and Canada map, so it probably only installed the lower 48 states. You will need to install the map on an SD card in order to have both maps on the unit.
Map update failed
https://youtu.be/C9JQGEK1-0o
2answers
I need an updated map for united states and canada
No updated maps are available for the Finedrive line of GPS'
How do i update my maps
Welcome to FixYa!
To update your Garmin device, go to this link https://my.garmin.com/maps/chooseDeviceType.htm?
  • Select your device type.
  • It will request to install the Gamin Communicator Plug-in.
  • Make sure that you connect your Garmin device to the computer before proceeding to install.
  • After the installation, it will automatically download for an updated map.
Note: Sometimes, there are no available updated maps and the update service will simply freeze. I'm not quite sure if this issue has already been fixed in Garmin's website.
To confirm if there are available maps, contact Garmin:
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Thank you for using FixYa.
Have a great day.
I have downloaded a file for an updated version of a map how do i transfare it to my nuvi
Welcome to FixYa!
US: 913-397-8200
Have a great day.
I recently purchased a Garmin nuvi(r) 1310(T) from Halfords in Manchester and was advised to get a "free" update after registering my unit, as it could be 1-2 years old. On checking there were no "free"...
If a new map becomes available within 60 days of the satnav first receiving a satellite signal you get it free. If you only got the satnav there may not be an update at the moment. While the satnav may have been a while in the shop Halfords keep the maps up to date. Even if there was not a free update available myMaps in myGarmin should show if there's an update which could be paid for available. If it says no update available you probably have the latest version. A new map normally comes out in November though the dates vary. Keep a check by logging into myGarmin and checking on myMaps. When the new map becomes available it should show up there. It will let you know if it's free or not.
If you want to check what year the map on your satnav is:
Press TOOLS (the spanner symbol)
Press SETTINGS (or LOCALE if your satnav doesn't have a settings icon)
Press MAPS
Press MAP INFO at the bottom of the map page
This will show what map you have and the year of the map. If your map is the latest version it would explain why there's no updates
Oct 22, 2010 • Garmin GPS
6helpful
3answers
Is there an update for the LG LN735 if so how can I download it
Called LG to get the update. There is a 2008 version available. Problem is you have to order it from them and the cost is $99 plus $15 for shipping and taxes. The LN735 isn't even worth that much anymore, it won't cost much more to upgrade to a newer GPS.
15helpful
3answers
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Map data availability
"I tried to load the new 2008 City Navigator but the update was interrupted."
You deleted your previous maps, therefore there are no maps on the unit. Try reloading the maps again and this time let it continue all the way to the end. It will take a couple of hours depending on loading all maps or only certain states.
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
