Question about Planar PDP-42BK 42 in. Plasma HDTV
Have a Planar P42BSAT. Screen Going dark
Have A Planar P42BSAT. Screen has been going dark, but I can still see the picture. It would clear up after about ten minutes when it first turned on, but now it just stay the same. I have already changed out two large caps on the power supply board which were blown. any ideas would help.
SOURCE:
  • 16 Answers
SOURCE: PLANAR PDP-42BK NO VIDEO SIGNAL
who changed the caps and what caps did they change, also there are two switches on the board one should be normal and the other on 30v
Posted on Jul 28, 2008
  • 16 Answers
SOURCE: Planar pdp42bk problem
change the c97,c19 and c16 caps below is where I got mines.
Got it from a site called digi-key.com their phone # is 1800-344-4539. The part #s are EF6225-ND you need 1of these, and E6105-ND you need 2 of these, the cost is $16 for all. Let me know how it went.
Posted on Oct 26, 2008
SOURCE: planar PDP42BK no picture
Check the 15v line that runs through all the boards, left, right and top.. If that has no power, then look on the ysus board (left one) there is a flyback reg (5pin) standard to-220 case surrouded by caps, it does dc to ac conversion, if you dont have the 15v output then the chip is bad. I just did 2 of these that had the same problem.
Posted on Nov 09, 2008
  • 4090 Answers
SOURCE: tv turns off will turn on then off right away
the internal overload sensor is engaging to protect the system. The parts cost to replace the faulty board is about $70 But you need the skills to open the tv and change it I recommend you get a professional to do it More expensive of course but a lot safer.
Posted on Sep 19, 2009
Testimonial: "very good im gonna jump right on that thank you "
budmrtn
  • 11361 Answers
SOURCE: power supply has blown fuse found two caps bad
You can contact them to see when they will have it back instock: http://www.shopjimmy.com/power-supply-unit-partnum-from-olevia-lt42hvi.htm
This the part number EEC-PWFSP27-000
Posted on Dec 06, 2009
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
TV loses picture
Sounds like your picture tube or bulb is going out. It depends on what kind of tv ( rp, lcd, plasma) it could also be a component issue.
Nov 22, 2013 | Televison & Video
Dark Picture
Get a lamp ordered asap. It won't be long and you are going to need it. You lamp is on it's last leg.
May 16, 2010 | Mitsubishi WD-65731 65" HDTV
Planar 997-2419-00 monitor is dark completely but you can still see the picture in the back. tell me what i need to buy from you.
ivettecorral, "Switch-mode-power-supply" is in partial shutdown mode. The monitor needs you or tech to fix it. Your display isn't any different than any other brand that has BLACK and not BLANK screen!!! Read more options that you have open to you in my fixya profile. Then decide what and how you will restore unit to operational condition. 12fixlouie aka louie12fix If this helps geting you started after you do some reading, come back and rate this response on fixya!!
Dec 15, 2009 | Planar Computers & Internet
Mac mini and Planar PL2010MW contectivity
have you tried changing the display resolution to lower at first so you can at least get a signal ?
Dec 27, 2008 | Planar PL2010MW Monitor
Planar PDP42BK no picture
Oct 27, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
Dark and red picture
First you can up the screen voltage, by finding the HV transformer. It has Screen and Focus control on it this it the Transformer that is in back of set and has an anode lead going to Picture tube. Come up on the screen control slowly and if the picture brightens with vertical lines then it's too high, The red problem is a small transistor that maybe located on the CRT board. It's probably shorted. There are about 3, each going to the different colors Red, Blue, Green.
Sep 13, 2007 | RCA F35317 35" TV
Planar PDP-42BK 42 in. Plasma HDTV Logo
142 people viewed this question
Top Planar Televison & Video Experts
Marvin
Marvin
Are you a Planar Televison and Video Expert? Answer questions, earn points and help others
