True 49 cu. ft. / 1388 liter Commercial Freezer GDIM-49NT Logo
Posted on Jul 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How old how can I find out how old my true freezer is I have a model and serial number
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Jul 05, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3071917
Points
27242
May I get the model and serial # to help you find out the year.
How do i find out how old a freezer is?
Search online to find the manufacturer's website. Call or email them. Be sure to have the model number and serial number. They should be able to help you.
Our True Freezer quit cooling properly. I'm not sure which model it is. Serial # is 10883769-6876. It is at least 13 years old. We would like to know who we could call to service it. Our location is...
Use this link for the True website fill in your zip code
http://www.truemfg.com/ServiceCoLookup.aspx?language_id=1&event_id=401&from=food&Country=USA
It may be more cost effective to find your local reputable fridge guy, True are a standard refrigeration unit and most parts are generic
Hope this helps
Gordon
LOST KEY, WOULD LIKE TO REPLACE THE LOCKS
You would not have to replace the locks. There is a number on the front of the lock. Most local locksmiths can look that number up and sell you a couple of these keys. If the locks have been damaged or "punched out" you can purchase replacement locks from a True dealer. Look under restaurant equipment dealers in your phone book. Have your model and serial numbers ready when you call.
IM CHECK THE 72-F OF A CLIENT AND ALL WIRING IN THE EVAPORATOR ARE DISCONECT.I NEED A DIAGRAM
i think the best thing to do is call true mgf. and ask them to fax or email the diagram for you they might want a serial number as well
Toll Free: 800-325-6152
hope this helps
I NEED A WIRING DIAGRAM FOR A TRUE FREEZERG M# T-35F
only way to get the exact one is to contact Ture at truemfg.com. They will ask for model and serial and send it to you.
Hope this helps.
I like the wire diagram from 3 door freezer swich to lights inside
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to "Support" and then do the "Ask the True service Dept." They will need your model and serial numbers and they will send it to you.
Need to replace, buy door lock
find model number , serial. local distributer or factory can get that for you
1helpful
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
6helpful
6answers
I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
