Zebra Printer 140-751-00000 Logo
A
Anonymous Posted on Jul 02, 2010
How do I change the ip address from the lcd display?
Mehandi Husain Suleman
Level 3:
  • Zebra Master 1,654 Answers
  • Posted on Jul 02, 2010
Zebra Master
Level 3:
Answers
1654
Questions
Helped
576920
Points
4530
Hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • 1 Related Answer
    Anonymous
    • 31 Answers
    • Posted on Jan 14, 2010
    SOURCE: No LCD display
    if there is no lcd display then most probably the display has gone bad.you can definitele get it replaced from a local store or from the manufacturer if in warranty.the manufacturers also have some paid repair plans if you are out of warranty.you can contact the respective tech support and get help.
    3answers
    Change ip address
    Type cmd in Start menu-Run. A little black window will open. Type: ipconfig/all and Enter. It'll list your IP among other info.
    If you want to change it: Start menu->Control Panel
    Type "adapter" int the search box. You'll have "Network and sharing Center". Click "View network connections". Select "Internet Protocol version 4 (TCP/IPv4)" and click Properties. There you can change your IP settings.
    2answers
    How to change ip address
    Method 1:
    To release and renew your IP address:
    Step 1
    Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
    Step 2
    Type "ipconfig /release" (without quotation marks) and press "Enter"
    Step 3
    Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
    Step 4
    Last, type "exit" (without quotation marks) then press "Enter" to close the window.
    you have a new ip address.
    Method 2
    It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
    Method 3:
    You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
    Hpow u change ip adres
    Method 1:
    Step 1
    Step 2
    Step 3
    Step 4
    Method 2
    It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
    Method 3:
    You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
    IP configuration
    You can set three IP parameters from the printer control panel. The available parameters are:
    • IP Address
    • Subnet Mask
    • Gateway (optional)
    The procedure for changing any of the parameters is the same. The procedure for changing the IP Address is given here as an example. Use the same procedure for the other IP parameters.
    1. Make sure the printer is on and paper/ribbon is loaded.
    2. Press the PAUSE key to place the printer in the OFFLINE mode.
    3. Unlock the Front Panel. (DOWN Arrow + ENTER keys at the same time.)
    4. Press the MENU key until the LCD displays "ETHERNET ADDRESS."
    5. Press the DOWN arrow key to access the first segment of the IP address to be changed. (Or press DOWN arrow again to scroll through the Subnet and Gateway segments.)
    6. Press the + (plus) or - (minus) keys to change the segment.
    7. Press ENTER to make the selection. An asterisk appears to the right of the value.
    8. If other IP address segments need to be changed, go to step 5.
    9. When Finished the [Pause] key twice to go ONLINE. This burns the IP information into the printer.
    The ethernet configuration is global to the printer, and takes effect immediately.
    2answers
    Change ip address
    I believe the information contained in this link, is better than the prattle I could post,
    http://whatismyipaddress.com/change-ip
    Regards,
    joecoolvette
    5helpful
    How can i change the ip and default gateway of barcode printer Toshiba B-sx4?
    I hope thisis understandable.
    1. Switch printer off
    2. Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
    3. Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
    4. Press [PAUSE]
    5. Press [PAUSE]. Display shows IP Address
    6. Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
    7. When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
    8. Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
    9. Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
    10. Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
    11. After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
    12. Step through the above sequences to get the GATEWAY IP ADDRESS you want.
    13. You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
    14. The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
    9helpful
    How do i change IP address for network printing
    yep!
    you mean the ip address of the copier?
    it is under general settings key operator mode
    here's how to do it:
    1. set the machine to copy mode (ready to copy displayed on LCD)
    2. press FUNCTION
    3. press 1
    4. press SET
    5. press 9
    6. press 000 (as a default key operator password)
    7. press 1 and 9 ( 19 )
    8. the tcp/ip mode will display
    you may press clear to erase the current ip address;
    just press the number that corresponds to your desired ip address and asterisk (*) corresponds to dot ( . ); after you input the new ip address dont forget to press SET to save the settings
    press STOP TO EXIT
    that's it :)
    2helpful
    Dell 5100cn change ip address
    Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
    If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
    The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
    On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
    Note: Make sure the use the correct IP address within the network's range.
    1helpful
    How do I change the IP address?
    Use Operator Panel (LCD display and buttons) to navigate to Network section of the menu. Switch IP ADDRESS SET from AUTO to MANUAL and then you'll be able to enter the IP address manually from the operator panel.
    How to give ip address to workcentre m133 network printer
    : You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
    Top Zebra Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    ExpressFiX
    ExpressFiX
    Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
