SOURCE: FRONT DISPLAY SHOWS (PE0-000)
When the hv board is replaced, the display must be re-programmed using the code inside the upper compartment on the right side.
SOURCE: Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
perhaps there is ice holding it in because that tab is all that holds it.
SOURCE: Maytag Ice20 refrigerator
You have a bad high voltage board and as the other user said call the manufacturer they are assisting with this problem.
SOURCE: Frozen code
did you change circuit board ???? youll need to reprogram the refig, there should be a paper that came with the new part( if indeed youdid cahngeit) if not there should be underthe right front corner of refig tapedup under behind the toe grill a tech sheet in which they should explain "programming your refrig"
