Barbeques Galore Capt'n Cook 4-Burner (NG) Grill Logo
Posted on Jul 02, 2010
My flame is very low when lite and grill will not get beyond 200 degrees. This happens intermittingly.
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jul 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
5972
Points
62
It is most likely the propane regulator. If it is under a year old the company should replace it for free. (The regulator is located on the gas line and is a round metal object near the propane tank.)
Low flame isnt exactly low! 200 degrees is suppose to be low it goes over 300degrees
You need a liquid vapour mechanical thermostat ( control knob & thermostat).this will activate the low flame procedure as it should, you need to use a gas safe engineer to fit and test your appliance controls, this will be done to makesure your appliance is safe to use once the repair has been carried out.
Jul 13, 2011 • Grilling
I just replaced and old worn out built in Turbo with a new model. Both are propane versions. After installing the new model works fine but does not generate enough heat. With all four burners on high...
If you are using a 20Lb LP Gas Tank, rather than hard piped to the grill or you're using Natural Ga, here in may lie the problem. If it is Natural Gas, was the grill converted or ordered for Natural Gas? If not, that's why it' not heating well.
If you're using a 20Lb grill tank, do the following:
1. Turn the Propane Tank Valve OFF and disconnect the hose from the tank.
2.Wait 5 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
3. Once the valve is fully open, light the burner farthest from the tank first and turn the control knob to HIGH. Does the flame height look correct for being on HIGH? If so, light the remaining burners the same way, Do all the flame hieghts look correct? If co, close the lid and allow the grill to preheat for at least 20 minutes. Did the grill thermometer go higher that 200 degrees F. If so, you solved the problem. Always remember to turn the tank valve ON very, very slowly.
If that did not solve the problem, the thermometer may be incorrect/faulty. I had this happen myself, with a new grill. To test it, invest $5.00 in an Oven Thermometer, like you use in a regular oven, It sits on the oven shelf. But, in this case it will sit on the center of the grill's cooking grates.
Light the grill and preheat it for 20 minutes. Loo k at the grill thermometer and then lift the hood and look at the oven thermometer. The oven thermometer may be as much as 200 degrees higher. That's because it's actually reading the temperature at cooking level, not up in the air, where the grill thermometer is.
I never replaced my grill thermometer. I continue to use the inexpensive oven thermometer, because it's giving me the actual temperature, at the level I'm grilling at. And I, do a lot of grilling.
Hope this helped you troubleshoot and solve the problem. Pleas let me know and Happy Grilling.
My weber grill won't heat up beyond 200 degrees - why>
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ,,./,./
2answers
The flame does not spread evenly to all the burners and it will not heat beyond 200 degrees
Fuel starvation is the likely cause. Pressure regulator is bad, or an orifice is clogged.
My Jenn-Air grill model 720-0336 when you lite one burner it will lite but with low height in flame and as you tun on another flames go to 1/8 inch high as you turn on the last burner than go out. This...
It could be a couple of things. First you could be low on propane or natural gas depending on what you use. The second thing is that over time the little holes in the burners clog. You can poke them clean with a toothpick. Or if they are rusted you will need new ones which you can find from an appliance parts dealer. If they don't have your part start looking on ebay because your grill is discontinued. Jenn-Air might be able to help you find the parts if you can get in touch with a customer service rep.
2helpful
2answers
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Gas grill does not get hot.
Try replacing the hose and regulator, easy to do and inexpensive.
5helpful
My grill does not heat beyond 300 degrees.
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly. I HAD THIS PROBLEM JUST LAST NIGHT AND FIXED IT RIGHT THEN.
8helpful
Top Barbeques Galore Grilling Experts
Paul Carew
john h
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
