Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
Posted on Jul 01, 2010
How to wind string around the bobbin
I need to know the instuctions for adding new string to my Black and Decker Grasshog electric trimmer.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
947
Points
The manual is available on line if you do not have your hard copy OR you could purchase a spool already loaded and ready to go.
  • TERMAC51 Sep 05, 2010
    WHERE ON LINE, IF I HAD THE INSTRUCTIONS ........
How do you rewind the string on the black and deckder grasshog
It's annoying I know, but there should be a little notch in the spool, wind the string evenly round one groove. notch it, then do the same on the other groove but in the opposite direction. Hope this helps.
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
2answers
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
I require a grasshog string cutter/assemby/and screw. wgere can I order one?
Check in your area to see if you have a Dewalt tool store in your area. They may have what you need to order parts for this unit.
Black and Decker Grasshog Malfuntion
Make sure to look at the spool. There should be an arrow showing which way to wind the string...Good luck...Lee
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
SPOOL
You have the string wound the wrong way. Wind in the other direction.
Jim
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
