The 016-783 error message indicates that “Cause – Could
not find the specified server path during file”.
The folder that the Xerox scanner job template uses to deposit the
scans in had previously been deleted, so I had recreated the shared
network folder. What I had neglected to do though was to recreate the
sub-folders that the Xerox Job Templates use for the scans.
After recreating the subfolders that the file repository setup
referenced in the job template I had no more error codes with that
scanning job template.
SOURCE: 016-781
The system failed to establish connections with the FTP Server.
Procedure
Set the “Sub-net Mask” and “Gateway” of the main processor correctly.
From the destination server, use “ping” to check that the machine can be “seen”.
From a Windows95 or UNIX machine, check that FTP connection to the destination server is possible.
SOURCE: Hi We are unable to scan through our fuji printer
Set "Sub-net Mask" and "Gateway" of the main processor correctly.
From the destination server, check that you can identify the M/C with "ping."
From a Windows95 or UNIX machine to check that the FTP connection to the destination server is possible.
If the machine is a DC 3535, check that the Ethernet Crossover Cable from the ESS to the Network Controller is connected and is free from damage. Refer to the Network Controller service documentation for repair procedures
