Panasonic DP-8045 Grayscale Copier Logo
Posted on Jul 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine Error Code E07-24 on a Panasonic Workio DP4510.
Anonymous
Level 2:
Champion:
  • Expert 224 Answers
  • Posted on Jul 05, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
224
Questions
0
Helped
65929
Points
450
There is an error with the finisher/sorter
  • 4 more comments
  • wymanl Jul 06, 2010
    So is there any way to reset the finisher/sorter?
  • Anonymous Jan 07, 2011
    That error relates to the staplers shift motor. I have seen the stapler come out of its tracks. Open the front door of the finisher. Grab the staple assy by hand and move it back and forth. The movement should be smooth.
  • Pretty Doll
    Pretty Doll Apr 01, 2019
    can't solve this problem by this method
How to setting E02-02 code panasonic photocopier machine
Hi.
Panasonic Workio DP-1820P error code E02-01 These instructions describe error code E02-01 solution for a Panasonic Workio DP-1520p, DP-1820P copier machine. This should solve your problem; this introduction will help you to troubleshoot some common error messages related to Panasonic Workio DP-1520p, DP-1820P Error Code E2-01, E2-02, E2-03, and E2-04 that you may receive.
Meaning of E02-01 the Error Code:
E02-01 means the Tray 1 cassette lifting motor unit fault. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, this usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes.
How to fix the error:
Maybe a problem with tray 1 lift motor either you have a bad motor, Pull the paper tray out and see if the paper is lodged behind the tray, Also make sure the white coupling on the rear wall is in one piece. Check that the flag on the back of the tray is still present. Mostly it is broken and sometimes can be repaired, and otherwise, you have to change it, and to open the back cover and reach that (Part no is (DZTY000357 Paper Lift Motor Assembly, lift up drive).
Some of the possible causes:
  • Remove the tray and check for paper behind the tray.
  • Check paper falls back causing the gears to break.
  • Check cassette Lift Motor connector.
  • Replace the Tray 1 lift motor.
  • Check the Mainboard.
Good luck.
Machine error E01-21 how to fix it?panasonic dp4510
Hi Ahmad the link below is a list of error codes for panasonic printers & copiers, E1-21 Half speed scan home sensor home....CHEERS..
http://officeimagingsystems.com/id171.html
How do I clear error code 04-01 on a Panasonic DP4510 copier
my dear you selct facion and A3 origanal 3 selact same press after you press f9 press you selct 6 no file you inter after 4 heatr code reast
Error code 410 in panasonic copier DP4510
just press on this link and there is multi solution for the code error okay man===> http://www.manualslib.com/manual/360974/Panasonic-Workio-Dp-2310.html?page=209
3helpful
2answers
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
