The NHS-B has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
P.S. If you did splash too much water then wipe up as much as you can. Leave it out on a towel or paper towels to allow the excess moisture to evaporate. If you dump all the water out of the brewer (and tank) then you will need to pre-fill it with a pot of water PRIOR to plugging in the brewer. Follow the set up instructions in the manual. Let it heat up and try again. If it's still leaking then there is a hole in the tank. Call for service.
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
If you will get the model and code date from the bottom of your brewer and call customer service at 800-352-2866, we will be happy to assist you with resoloving this problem.
The brewer probably has a bad seal or gasket. By the date code, your machine is 5 years old. If you call Bunn Customer Service they will be able to offer you an exchange of your old brewer for a new one at a reduced price.
The only place I know of that you might be able to find a replacement tray for this style of brewer is from your local Bunn repair shop IF they have a used unit laying around that died from something else. Bunn will not even send out these parts to their repair centers. Good luck!!
