Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen text.Hope this will solve your problem.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Can you please advice same process for a 34788 cooltech? How do I access the service menue please?
CAN ANYONE ADVISE TO ACCESS THE SERVICE MENU 34788 TO PERFORM THE CALIBRATION? know the process with the 20 Lb weights. just need to know what access code is required to gain in to service menu?
Access code for Robinair 34788/34788i is 2200. hope this will help you.
and the service menu of the 347002k?
