SOURCE: How Do i have a
CAN'T BE DONE AS THE FRIG WORKS OFF THE FREEZER,THE FREEZER MAKES ALL THE COLD AIR FOR FOR FRIG.IF IT'S NOT FROST FREE JUST TURN THE THERMOSTAT OFF TILL FREEZER IS DEFROSTED,IF FROST FREE YOU SHOULD'NT HAVE TO DO ANYTHING,HOPE THIS HELPS-MIKE
SOURCE: Haier HRF-488FR/***
hi there, i noticed your post was in 08 did you find a seal to fit your fridge i have a hrf 488 fr/a and fisher and pykel are looking after them now... they advised be that this model is obsolete now and no longer have parts available.
SOURCE: My Haier mini fridge (model
Hello
Number 1 may be the warmest.Set it to 2 or 3 and give it some time,a couple of hours to level out.
If this does not work try a higher number.
If still no luck then the thermostat or sensing bulb is bad and should be replaced.
SOURCE: sir i have haier refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: Model No 8.58616E+1 Fridge not keeping
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
