How do I set my TV to "LINE"
I have a PVR hooked up to my (BELL Satellite) TV and it runs through my DVD/VCR. I believe the DVD should be set to Channel 3 and the TV should be set to LINE. I pressed something on the remote by accident that changed the TV setting to 03 and I can't seem to find a way to change it back to LINE. Thanks in advance for your help!
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD
Player Combo press DVD/VCR once. After programming a VCR Combo device,
you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a
DVD Combo device, you will be able to control channel selection, volume, and
DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and
then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 to 5, trying each code for your
brand until you find one that works. If it still doesn't work, try Searching
For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when
the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are
searching for.
Thank You
