Apple iPod nano Logo
Posted on Jul 01, 2010
Battery Life How do you check available battery life on I-Pod nano
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
136
Points
My ipod battery wont charge more that 1 line why is this
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jul 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
2492
Points
19
It shoud show on the right hand side of the screen
tom
IT SUPPORT
Its not charging
Patty:
It sounds like the battery has reached the end of its usable life.
If the iPod Nano that you have is the same that is pictured above, then ifixit has a procedure for replacing the battery.
Note: The repair is listed as "Difficult", so you may be challenged by it:
http://www.ifixit.com/Guide/Repair/Installing-iPod-Nano-2nd-Generation-Battery/422/1
Thank you for using FixYa and Happy New Year!
Bought ipod (white) 1 gig, from ebay .. will not play, will not start, just blinking lights. held play for 3 sec to get green light, still nothing, all controls only render orange and green blinking ......
Hi, problem can be solved. You need t look out for two things:
1. the battery of the i pod,
2. the memory of the i pod.
Checking the battery, the battery cell of the i pod might be too weak to power up the i pod, so you need to test with another battery before purchasing a new one. It may also need to be charged properly for longer hours before it can be able to power up the i pod.You can also check that out.
Checking the memory of the i pod. The memory of the i pod can also be the cause. Virus or corrupted applications can cause to malfunction.
After checking battery, if it does not work that means you will need to flash the i pod for the memory to be restore back to normal again.
Take care.
Ipod Nano 5th Gen. 3 months old and died--won't restore either.
A possible problem with the battery. Battery life depends on how you frequently used the devised and how you handled the proper cycle to charged and drained the battery.
Battery charging should complete it's charging hours and you have to properly fully drained the battery at least once a week, this will make the battery life go longer.
Initially try to plug and connect the Ipod into your computer and see to it that it was turning ON, or it was giving any sign that it was responding when you connect it to the computer.
Is there any incidents happen that you got a problem on charging the unit, or any like incidents like power outage on the area or a short circuit on the device charger?
Let me know here again for further instruction and clarification.
micro~
Is it possi ble to replace an ipod battery myself
take it to the apple store for a new battery.  I'd send it back for another one.
Ipod nano 8gb Low battery Life
Umm i have heard that you are supposed to charge completely before you use them, also the more you charge it when it is low the less life it will have...
1helpful
Poor Battery life
Battery life on a portable system is a contentious issue, and manufacturer's marketing of battery life doesn't help the cause a bit.
There are several factors that will determine the ACTUAL battery life of your system versus the ADVERTISED battery life.
  1. Battery type and watt/hour rating. There are 2 types of portable batteries, Lithium Ion (LION) and Nickel Metal Hydride (NMHD) The LION battery is longer lasting and has a more consistant power output than NMHD batteries, and is more expensive. The watt hour capability is based on the number of cells in the battery (normally 4, 6, 9 and sometimes 12 cell batteries are available) The higher the watt hour rating (more cells) the longer it lasts. LION batteries are more expensive and higher watt hour ones are more expensive. So if you took the best price on the battery you bought, or if you got a system on SALE/good deal, you may have gotten the lesser battery in the DEAL.
  2. How the system is used on battery and power management settings. When manufacturers advertise battery life, they use the mose economical use of power configuration to get that possible life. LCD brightness to minimum, nothing running inoptical drive, minimum accesses of HDD, system running in cold room to minimize fan operation and essentially doing just enough with the system to keep it from going too sleep. They turn off every feature that can be turned off, the most powerful brand new battery available, and the "LIFE" they get in that senario, is the one they advertise. So, if you are playing a DVD, with all power management off and the LCD up full bright, your battery life may be less than 10% of the advertised life.
  3. Age/number of recharge cycles of the battery. Battery warranties are generally 1 year by most major manufacturers. This is because they consider the battery a consumable item and it gets used up. The normal battery has a life of 300 to 500 recharge/discharge cycles. Some last longer, some don't and are replaced under warranty. If the battery is not a year old, you can likely get it replaced by the manufacturer of the system under warranty.
  4. If you buy a replacement battery, get a LION battery with at least 9 cells. It will be more expensive, but you get what you pay for in batteries.
Warranty information can be found here:
https://secure3.tx.acer.com/FindSystem/FindSystem.aspx?title=Information
2answers
Battery life
Charge it 4 longa coz itz new
Battery life?
The iPod nano, introduced September 7, 2005, provides fourteen hours of battery life.
How long is the iPod's battery life? iPod nano?
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
