The SN on this model is well hidden. First you need to remove the seat of the scooter. Then , remove the back cover of the batteries. If I remember correctly, you have to remove both batteries and the SN is in that area. On some of these models the SN is on the lower end of the seat post. It is on a tag that I think reads Pride Mobility Products in silver and black. Hope this helps
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Undo the centre wheel nut and remove along with the washer, jack the rear of the scooter off the ground then slide the wheel off the axle. If it will not remove, it will need knocking off from the inside rim. Be careful not to lose the hub key (a small piece of metal that locates in a slot in the wheel and axle) as the scooter will not drive if this is missing. To remove the trye from the rim, undo the 4 bolts that hold the two wheel halves together. When refitting the wheel, be sure to apply some grease to the axle before sliding on the wheel.
