When powering on this HP 2840 it says "Scanner Error 6"
What does the 6 indecate?
When poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Scanner Error 6 for HP Laserjet AIO 2840
Finally fixed the problem... hopefully.
Tools:
1 - torx screwdriver
1 - flathead screwdriver
1 - microfiber or some cleaning that doesn't leave dust
Fix:
Scanner Error 6, HP Laser jet 2840
Solved problem by cleaning inside of glass near moving scanner bulb. It was fairly clean except for a small piece of paper about a quarter inch long that became lodged in the corner of the glass. I suspect this was the culpret.
Make sure to remove all 8 torx screws on top the scanner unit, including the hidden two, under the keypad cover plate! Then carefully pry off the scanner cover to access the underside glass pane. I used a clean white t-shirt and the water vapor from my breath to clean, and it worked like a charm. Unit was still under a five year warranty, which probably wouldn't cover this issue anyway, and who wants to lug a 75LBS unit to the repair shop.
Good Luck!
Please Open It Scaner And Clean It Or Call Professional Eng 9220949183
I can not scan on my HP 2840. here is the error message.
an error ocurred during preview. If the scanner is being used, please wait for it to complete the task, and then click Preview.
Scanning has not worked for weeks. I turned it off and on several times.
scanner error 6
intermittent scanner error 6 on display console
OK, I HEVE A PROBLEM , MI MACHINE SAY A MASSAGE, ERROR SCANER 3/OFFAND ON AGAIN.
I TRY VERY TIMES THIS KEY, BUT DONT HAVE RESULTS.
YOU CAN HELP ME.
THAN JULIAN C.
I have the exact same problem and the machine will not let me do anything else! HELP!!
I have a message that says scanner error 6
how do i fix it, i got told that when i swich the machine on i must hold star and enter but that doesnt work
PLEASE HELP!!!!!!!!!!
I cant scan on my hp laser jet 2840 as it shows error 3 and prompts me to restart it for several times.
Our copier is set up to be used as a basic copier and fax it is not set up to fax. Someone pressed the scan button and know Scanner Error 5 is displayed. It says to turn off then on I have done this and it still has not fixed the problem.
hp 2840 scanner error 11
turn off then on
Scanner Error 5 here. Any thoughts?
Scannerfout 6 bij opstarten.
Scanner error 3, the All-in-one cannot print eather
download update from ware hp laserjet 2840
