Sony KDF-E55A20 55 in. LCD Television Logo
Posted on Jun 15, 2017
The tv turns itself off and then back on. the standby light flashes during the off period. I've noticed in the past that after watching the tv for an extended amount of time, and turing it off, and then shortly turning it back on that the tv wont come on but will have the standby light flash. Now it simply turns itself off after 10 or 20 minutes of being on, with the standby light flashing whiling it is off for about 30 seconds, and then comes back on again.
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Jan 16, 2008
SOURCE: TV turn on and off
Your TV has a power problem, it maybe high or low supply voltage that causes the TV to turn it self off because of an error. A technician from the manufacturer knows what error it has just by looking at the flashing standby light. Best is to take it to an authorize service center for repair... ^_^
Anonymous
  • 320 Answers
  • Posted on Oct 20, 2008
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
electroman
  • 1039 Answers
  • Posted on Apr 25, 2009
SOURCE: 13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Anonymous
  • Posted on Sep 28, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Anonymous
  • Posted on May 10, 2010
SOURCE: sony bravia 200 z tv turns itself off at random
EASY.. SWITCH AC OFF!!!
NEVER HEAR A SONY GUY TALKING HERE...
Media receiver "on" button flashes 8 times and turns the Pioneer TV to standby.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Kdl-46s2010 Turns itself off, standby light does not flash to show fault
This might be your main board on the tv. If the tv is still under warranty I would bring it back in for repair.
43helpful
3answers
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
12helpful
2answers
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
3helpful
Tv won't turn on, we were watching the tv and it turned off by itself and wouldn't turn back on. electric is good etc.
If there is no standby light then it is likely to be the fuse inside the tv. If there is a standby light then it could be many various things.
Standby light just flashes when power is turned on
Look, your tv is in Loose connection,, A lot!. Common problem on sony tv. OPen tv , resolder all ground area ( beside fly back ) and you will see again your tv !!!
1helpful
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
1helpful
TV doesn't turn on
When the set is turned on, the computer senses that something is wrong and immediately shuts the set back off. The standby LED will then blink a code, a certain number of blinks, to indicate exactly why the set was shut down. It is possible that your audio output IC is shorted, as this would make a pop or strange noises in the speaker just before the set shuts down, which it does to protect your speakers from burning up. The set should be looked at by a qualified tech familiar with Sony TV's.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
