Water reserrvoir of Cuisinart coffeemaker does not empty
I used to work for Cuisinart.
First off, as previously mentioned, make sure nothing's blocking the reservoir. In addition to that, make sure that ALL of the parts are in place (including the carafe, carafe LID, and filter basket--those are commonly forgotten). Then, take a solution of 6 cups vinegar, 6 cups water, and fill up the water reservoir. Let that soak for at least one hour. After an hour, try and brew the vinegar/water solution through. If it goes through, let it cycle all the way through, then brew a full 12 cups of water through to rinse out any remaining vinegar.
If, after waiting about 10 minutes, it doesn't at least start to go through, and you purchased the coffee maker 3 years ago or less, call Cuisinart at 1-800-726-0190, and see if you can get a warrantied replacement.
Check the water filter.If its blocked or clogged it will not let the water reservoir to get empty.
Its recommend changing the water filter
every 60 days or 60 uses, more often if you
have hard water.
For help and troubleshooting guide of coffee maker .Please click on the link below:--
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
thanks.
