You might want to review the manual below:
http://www.usa.denon.com/AVR-1908-OM-E_109.pdf
1) Make sure MASTER VOLUME is not set too low 2) MUTE should be OFF 3) Make sure nothing is plugged into the PHONES jack 4)Make sure the source program has a signal present - the inputs may not be connected to the selected source on the front panel (or try FM or AM for a source instead) 5) Check for proper connection at each of the speakers AND at the rear of the stereo. 6) Perform a microprocessor reset: a.Power the unit off, b. Press and release the "POWER" _while_ keeping both "Speaker A" and "Speaker B" buttons pressed. Once the display begins flashing in 1 second intervals, release both speaker buttons.
Hopefully, one of those steps will solve the issue. Please rate this reply if it was helpful - good luck!
