The problem may be the freezer drain heater has failed, locate the drain inside of the freezer compartment and check to see if it is warm, if not you may need to replace the heater.
Use a steamer to blast the drain clear... sometimes you need to install what is called a heat probe that feeds into the drain tube to keep it from freezing over... Help Me Find My Model Number RepairClinic com
Honestly, it really sounds like your problem in the drain is blocked and is overflowing causing a nightmare. I'm assuming it starts just at the bottom of the back wall just around the first set of drawers. There is a kit that they make that actually resolves this issue. Unfortunatly, after looking it up they actually discontinued that part for your model. Not to worry, I'll tell you how to build on. You'll want to remove the drawers and the shelfs and the back wall. For maximun ease I recommend turning the machine off for a day or two and letting everything thaw out. Once the back is off locate the defrost heater. It will run along the bottom of the evaporator. Now, find the drain hole in the trough below the heater area. Once you;ve done that find an aluminum can and good pair of scissors. Cut a strip that can fit down the drain hole, but not to small or too big. Be sure to make it a decent length. Take one end and sort of wrap it around the defrost heater directly above the drain hole then have the rest of the strip go into the drain. How this works is everytime the machine goes into defrost, this ice will melt and the water will fall to the trough where it will go to the drain. The bad thing is hot water actually freezes faster than cold, but with the aluminum improvised drain heater, heat from the element above will pass downward to the aluminum keeping the water warm enough to not freeze as it goes down the drain and finally out of the machine. Your problem will be a thing of the past. Good luck
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
I would check your door seals to make sure they are doing there job. If warm moist air gets into an area of cold this will happen. You may need to get new seals for your freezer door.
Not sure of your model number and manufacturer, but in some freezer there is a seperate drain heater that should stay on for the complete defrost time. (the defrost heater will shut off when the evap coil reaches a certain temp, and the rest of the defrost time only the drain heater is energized.) That would be the very first place that I would start. Hope this helps
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
the drain pipe you cleaned out has a p-trap that holds water. after awhile this trap will build up sludge and possibly freeze up. i recomend defrosting the drain pan again and try some way to forcfully flush hot water thru the drain. I use a turkey baster filled with water to do this. if the drain continues to freeze you may need to install a heat trap to keep drain from freezing.
a heat trap is just a piece of 10-12 guage solid copper wire with about 3 inches in the drain and the other end wrapped around the defrost heater which is the BLACK rod attached to the bottom of the evaporator coil in the freezer compartment. if you need any further assistance just let me know Peyton
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
