Precor C954i Experience Treadmill Logo
Posted on Jun 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key STuck Error
After brief use of treadmill the "key stuck error" appears and machine shuts down.
John Mazmanian
Level 3:
President:
  • Precor Master 832 Answers
  • Posted on Jun 30, 2010
John Mazmanian
Precor Master
Level 3:
President:
Answers
832
Questions
0
Helped
628575
Points
2056
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
2answers
What does the f3 error mean on a cp6500 brother sewing machine?
https://support.brother.com/g/b/manuallist.aspx?c=ca&lang=en&prod=hf_cp6500eus&flang=English&type3=626&type2=69
It appears that all "F" error codes need a dealer service. The old standby is to unplug it and wait 30 minutes before plugging it in but don't get your hopes up.
Stuck key on machine wont start
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 35 9 35i Treadmills Consumer SPORTSMITH net
Stuck key
Corrective Action
Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
Precor 535 stuck key
Corrective Action
Precor gfx 9.33i displays "stuck key"
Corrective Action
I have a precor 935 that is showing error 5 stuck key that wont clear. any ideas
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
Corrective Action
Precor Error Code 05
On switching machine on `STUCK KEY` appears on console and machine will not work
Corrective Action
Repair Parts for Precor C956i Treadmills 120VAC 240VAC SPORTSMITH net
Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
Stuck key problem
Corrective Action
3helpful
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
