It will not take the password if you have changed it. 12345 is the default password that comes with factory installation. But you can always change the password.
Type *#7370# on your phone. This will restore your phone back to original factory settings but be sure to back up all your phone memory data like contacts, calender entries, notes etc cos otherwise your whole data in phone memory will be lost.
just a little information...
PDA USB Sync/Charger/Data Cable for Sony-Ericsson P800,Sony-Ericsson P900
Features:
USB Sync/Charge Data Cable for Sony-Ericsson P800,Sony-Ericsson P900
Auto Sync with computer in USB port and charge Sony-Ericsson P800,Sony-Ericsson P900 PDA with same cable
Directly connects with USB port, need no extra power
Plug and play, need not software installation
Eliminates the need for cradle and AC/DC converter when traveling
Compact, lightweight and easy to use
One of the best USB hotsync data cable for Sony-Ericsson P800,Sony-Ericsson P900!
If you experience problems when using the USB cable during synchronisation:
Check that the USB cable is properly connected to the phone and the computer.
Make sure the phone is turned on.
Restart the computer, without disconnecting the USB cable or turning off the phone, and try to synchronise again.
Well sorry to say but u have no memory card slot in it ....u wil only be able to use 40 mb.... Well bad tht u have a VGA camera wid a resolution of 640x480....:( Look at the bright side u got a mp3 player and radio...:)
not too sure what you mean here.you can reset bios to default or can set bios to factory reset.to set default ...when you turn on pc ,message at bottom left hand screen indicates which key to press to enter setup(bios setup) note...its very brief;mines f 10 for instance.at startup press this key and select load default then select save settings and exit;then ur pc restarts with default settings.
To reset bios to factory requires disassembly.
you locate rtc and remove battery(looks like large watch battery)for 5 minutes then replace,reassemble and restart pc.you dont need to know what rtc means(real time clock)or what it looks like cos the battery is right next to it.
