I cleaned my Ecoquest, plugged it in and all was working fine, went back to move the unit to its usual perch, noticed that all of the lights were off. I unplugged the unit, plugged it back in and nothing happened. I checked the fuse, plate, etc, all good. Please help with other solutions.
Assuming that the unit was working fine before you cleaned it. Did you remove the back lower panel while cleaning it? It the panel that holds the electrical socket and fuse. If you did, check to see if the electrical connector is seated to the main board. Also check if the keyboard connector (the one that looks like a telephone jack) is plugged into the main board. Also, check if you model has a switch on the back that it is set to the on position. And press the power switch on the front keypad to see if that make the unit work. That all I can think that might have gone wrong.
