I have a microwave that is not working(H5470N0GB/03). The problem is that the door will not latch closed. Either the latching lever, or spring connected to the lever is broken, or the spring has simply popped off the lever.I am not sure how to get the outer section of the door off to check the latch mechanismlatch on the door. I can see no screws, so it may simply lever off, but I am not sure.Any advice please.
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
