Question about HP Compaq 8510p Notebook
Why has screen gone black on compaq 8510p. Can vaguely see print
    President:
  • 2,600 Answers
Sounds like either your backlight bulb has failed or the inverter that powers the bulb has failed or a connection has come loose from the inverter to the LCD panel. Unless the laptop was "Jarred" or dropped, I doubt the bulb has burned out....most likely if no damage occued, the inverter has failed or there is a loose connection with the inverter.
Posted on Jun 30, 2010
  • HP Master
  • 5,660 Answers
Rosie_dent,
As has already been stated, it may just be a loose connection to the Inverter, or the Inverter may have failed.
The LCD screen cannot give off enough light by itself, therefore a Backlight Bulb is also used.
The Inverter provides power for the Backlight Bulb.
With the HP Compaq 8510P, the Inverter circuit board is located inside the LCD display panel, and right below the LCD screen itself.
[The terms used here, Inverter, Inverter board, and Inverter circuit board are relate to the same component]
Viewing the LCD monitor screen, you will note there is a 'frame' around it in the front. Resembles a picture frame.
This is the Bezel.
Essentially the Bezel just pops off.
(There is a CORRECT procedure, Do Not attempt it until you have read further!)
The Inverter circuit board is right behind it at the bottom left.
An Inverter board for this laptop ranges around $20.
One example of a place that sells the Inverter. (Not an advertisement for the website)
http://www.sparepartswarehouse.com/HP-Compaq,8510p,AK900US,Laptop,Inverters.aspx
How to replace the Inverter,
http://www.insidemylaptop.com/open-display-replace-inverter-board-hp-compaq-8510p-8510w-notebooks/
Step 6 gives a close-up look at the Inverter circuit board, and the connections to it.
Step 7 shows the Inverter circuit board removed.
Might just be a loose connection.
See where the cables, (Wires) plug in on each end of the Inverter?
They can come loose.
Especially the one on the Left.
This is the power cable TO the Inverter.
Repeated opening, and closing of the laptop, can cause this cable connection to come loose.
Posted on Jul 01, 2010
SOURCE:
How to fix hp compaq 8510p overheating vga
Clean the fan and radiator before it's too late!
Aug 07, 2014 | HP Compaq 8510p Notebook
Graphic importer missing
If you could tell us your exact issue, i.e. what you are trying to do this could be answered more easier. The question is a bit vague.
Regards
Jon Legg
Apr 21, 2012 | HP Compaq 8510p Notebook
How to clear bios password in Compaq 8510P Thanks
hello sir ... enter 3 time wrong password then u will see a code like this CNU1234ABC send me code ill wil send u master password Thanks
Oct 27, 2010 | HP Compaq 8510p Notebook
Breaker/fuse on hp 8510p
There are no fuses that you can see on the outside of any laptop. They are on the motherboard and they are inside the battery itself. You need to give us more info or perhaps attach a picture of the issue and explain how you shorted what.
Nov 13, 2017 | HP Compaq 8510p Notebook
Is there a wireless hardswitch somewhere on HP Compaq 8510p
There is a wireless button the computer..
Its couple of inches beside the power key...
or the place where we have the HP logo...down below that there would be wireless Button/LED
Hope this works
Regards
KEN
May 11, 2010 | HP Compaq 8510p Notebook
I need to swich to external screen, keyboard and
Use the key combination 'Fn' and 'F10'..
Else use the key combination 'Fn' and the funtion key which has a monitor symbol printed on it.
please come abck and vote for me if this helps you or also if you need more clarification. Thnx
Mar 28, 2010 | HP Compaq 8510p Notebook
Yes there is a wireless hardswitch on this machine it is 2 to the right of the power button once pressed on the bottom left of the machine an led should light up so you know its activated
Mar 18, 2010 | HP Compaq 8510p Notebook
After the start up screen my screen goes black. Whats up and how do you fix it?
graphic card is not being used check and see if grapic drivers are loaded and rdy then reboot and see if theat helps
Nov 20, 2009 | HP Compaq 8510p Notebook
HP Compaq 8510p Notebook Logo
1,504 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
