Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
SOURCE: Pyramid SE301-VL amp wiring confusion...
Captain_Bill,
Red - should be fused & is the +12Vdc system supply voltage.
Chassis = System ground.
Individual Green, Grey, & cooresponding blacks will be the right & left chan Audio ins (Black = neg).
Paired bl/blwh, br/brwh, grey/grwh, & green/grwh will be the audio outs.
Hope this helps !!!!
Dale EE
SOURCE: pyramid ps-36kx
Generally, the fuse only blows when the rectifiers fail. In other Pyramid supplies, they use a square, 4 terminal bridge rectifier. They probably use the same thing in your supply.
Let me know if you have any other questions.
SOURCE: How to hard rest PDAL with I-Mate keys. How to skip Alignment procedure with I-mate keys
MSP_RemoteAlignment use this software to skip that screen !
SOURCE: i-mate jasjam multi language(arabic)?
hi there!
thanks for using fixya.com!
If you have bought your PDA anywhere in the middle east, the software is already installed you just have to select your preference.
pls check this website for further information about your I-mate.
https://www.imate.com/Support_DeviceSupport.aspx
thanks and regards!
pls do not forget to rate me with my solution.
