Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
Posted on Jun 29, 2010
Remote starter doesn't function
Hi, I have a 2002 Nissan Sentra with a remote starter; I bought it second-hand in 2009 and the system was already installed.
It worked perfectly until a few weeks ago.
Now, when I try to start remotely, the car blinks two times and nothing happens, no start.
Do you have any idea what should i check first ?
Thank you for your help,
Steven Fredericks
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Jul 04, 2010
Steven Fredericks
Contributor
Level 1:
New Friend:
Answers
36
Questions
Helped
19867
Points
73
If the battery was replaced or any terminals removed, you may have lost the tach programming for the remote starter. Goto http://www.bulldogsecurity.com/bdnew/installmanuals.asp and look for the remote start unit you have in the manuals and it will tell ya how to reprogram the tach memory.
Why does it lack spark?
Part 1 -How to Test the Ignition COP Coils (Nissan 1.8L)
troubleshootmyvehicle.com > Nissan > 1.8L
Feb 12, 2013 - What Tools Do I Need to Test the COP Coils. ... coils (most commonly known as the COP ignition coils), on your 1.8L Nissan Sentra is pretty easy. ... When one COP ignition coil fails... that cylinder goes 'dead' due to a lack of Spark and is said to be misfiring. .... 2000, 2001, 2002, 2003, 2004, 2005, 2006 ...
Part 2 -How to Troubleshoot a No Start (Nissan 1.8L)
Jan 17, 2013 - Checking for Spark With a Spark Tester. ... Your 1.8L Nissan will either have a distributor-type ignition system or the more modern COP ... A BAD fuel pumpwill cause your 1.8L Nissan Sentra to Crank but Not Start... since the ... Still, the other method that I've used to test for a lack of fuel... is spraying starting ...
2002 Sentra 1.8, no spark, code 0505... - Nissan Sentra Forum ...
www.b15sentra.net > ... > Technical Discussion
Nov 4, 2008 - 15 posts - ‎3 authors
I have never had a problem with the car before (02 Sentra 1.8/auto), so I had no need to post ... Originally Posted by Black B15 ... Join Date: Jun 2005 ... Can you see if the coilpacks are getting spark & work back from there? how many spark plugs do i need ? - Nissan Sentra ...
Mar 19, 2010
Spark Plug Replacement - 2002 GXE 1.8L - Nissan ...
Oct 12, 2009
1.8s starting problems - Nissan Sentra Forum - B15 ...
Jun 23, 2009
No start on 1.8L 02 GXE - Nissan Sentra Forum - B15 ...
Apr 11, 2009
More results from www.b15sentra.net
Where is the starter from a 2001 nissan sentra located
Where is the starter on my 2001 Nissan Sentra?
I have removed the air intake and the battery and everything on that side - I still can't find the starter!
I need the hook up diagram for the cs34-ii tx remote starter for a 2002 nissan sentra gxe
the cs34-ii is a universal remote you have to look under your driver side dash and get your unit model number then go to www.crimestopper.com go to the support tab go to manuals and then manuals again and look for your model number that you have got from under your dash and then you should be able to get things straight i got this info from calling the crime stopper's tech support
2helpful
2answers
1helpful
My nissan sentra 95 wont start and its not the starter
it sounds like a starter kill relay was installed on your nissan, if there is a relay in line with the black/yellow or black/blue starter wire under your dash you may need to bypass it, or you might need to reprogram your remote to close the relay when you unlock your doors
1helpful
Keyless entry system installation
Seeing you have a 2009 i would highly recomend installing the astrostart in it wich you can get with keyless entry installed in the astro start. And the great thing about astro starts is depending on were you live you can set your temperature for hot or cold in the interiour so if you live in California you can turn your ac on before you even get in the car or if your like me and live in north dakota you can turn your heater on. But after installing just the Keyless entery systems i have had customers come back to me and decided that they whant astro start. and if you do go with the automatic car starter i highly Recomend AstroStart Brand they simply are the best out there. hope this kinda answers your question
Please leave rating on my solution
Thank you
Top Bulldog Security Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
John
John
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
