Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
Posted on Jun 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i press my on switch the jets come on then go off
When i press my on switch the pump comes on then goes off after about 5 seconds. removed the tube from the switch tried blowing down the tube and it stayed on a little longer . checked the mains board and found the box next to the switch buzzed then stopped it has finder on it any solutions would be appreciated
Alan
Level 2:
Scholar:
  • Expert 80 Answers
  • Posted on Jul 04, 2010
Alan
Expert
Level 2:
Scholar:
Answers
80
Questions
0
Helped
90071
Points
128
The switch is availiable online. google "jacuzzi air switch" and you should have several sites to choose from. There are pictures of the switches, just pick the one you need and buy. I have purchased from most of the suppliers online and most are very reliable.
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
I woke up to no water my pump kicks on and hums for 3 to 5 seconds and quits
It sounds like it is seized with the overload relay cycling it to save the motor. It needs to be dismantled, cleaned and possibly rebuilt. Check the price of a new one it may be cheaper.
The jets on my Cielo tub will not go on when I press the button to activate the air jets.
This sounds like the motor is either bad or the air switch in the motor is bad or...the air button on the top of the tub is bad.
Remove the pump and take the air switch out of the motor. Then plug the wires that went to the two terminals on the air switch to each other and plug the pump into an outlet you know has power.
If the motor comes on then you know the pump is good.
Now put the air switch back into the motor. Take a McDonalds straw and with the pump plugged into an outlet blow extremely hard into the straw placed into the opening of the air switch. If you can get the air switch to "click" and the pump comes on then you know you have a bad air switch. If the pump does NOT come on then you know you have a good air switch and a bad air button on the top lip of the tub.
Any Questions give us a call on Monday.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 • Home
Have a 2003 dyna the check engine light comes on and the tail light goes out,the speedo quits working, and it feels like one cyl is dead for about 15 seconds, and when the light goes out all is well. can u...
To Get the codes you need to follow these steps:
1. While holding the odometer reset switch in Turn the ignition swithch to IGN. Make sure Run/Stop is in the run position. When you release the reset switch does Diag Appear? If yes press and release the reset switch, PSSPT should appear.
2. Flashing P= DTC's for ECM press an hold reset switch for more than 5 seconds you should have a device response.
3. To Choose the TSM/TSSM/HFSM Codes press and release the reset button a flashing S should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
4. To Choose the Speedometer Codes press and release the reset button a flashing SP should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
5. To Choose the Tachometer Codes press and release the reset button a flashing T should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
If any of the above have none displayed you are ok.
If any of the above have DTC's displayed then press and release the reset switch to see if any more are displayed.
After writing down the codes then press and release the reset switch and the part number of the module will be displayed.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
Fill tub, press button, hear motor but no bubbles,etc coming from jets
Are the jets open? The center of the jets turn to adjust the pressure of the jets. If this is not the problem, there may be a problem with the impeller in the pump assembly. If you here the pump turning and not buzzing, it could be an air bubble in the suction tube. This tube is the one coming from the front of the pump, if the pump is higher than the tube coming from the tub, or if there is a high spot in the tube, an air bubble is a real possibility. If the tube is level with the pump, there should be no problem with air bubbles and the problem lies in the top part of this paragraph.
I have an old AquaWhirl tub that was out of commission for several months because of a breaker problem. I replaced the breaker but when I turn on tub I get 5 seconds of normal whirl followed by a big burst...
Due to your tub setting for a long period of time, you have a simple air lock in the jet hoses.
Find the pump - locate the jet farthest from the pump and using a funnel slowly pour water in that jet until water starts coming out of the other jets.
Turn you tub on it should work fine. If this does not solve your problem you may have to loosen the top hose at the pump and allow the air to escape while being replaced by the water you are pouring in
Mar 05, 2010 • Home
1helpful
My sony mp4/mp5 digital camera refuse to come on after charging.
Hey richy I think I have the same gadget. I press and hold the power button for more than 5 seconds until the "light of your life" is displayed
Starts but dies after several seconds
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
3helpful
I have a hayward s200 sand filter. When I vacuum, i backwash but dirty water doesnt seem to backwash out, just clean water. When I turn filter on small amounts of dirt you cant see come out of jets and re...
Are you using the rinse setting for a few seconds following the backwash? If not, once you finish washing, stop the pump, change the valce to rinse, then run it about 3 to 5 seconds. Shut down then switch to filter and the particles should stop coming back to the pool.
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
