Try these steps first. I assume you are using IE 7. If these steps do not work try reinstalling your IE. Let me know if you need anything else. Good Luck.
Method 1: Clear cached data in Internet Explorer 7
loadTOCNode(2, 'moreinformation');
To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
- Open Internet Explorer 7.
- Click Tools, and then click Delete Browsing History.
- In Delete Browsing History, click Delete All.
- Click to select the Also delete files and settings stored by add-ons check box, and then click OK.
A progress bar is displayed to indicate that the browsing history is being cleared. After this process is complete, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 2.
Method 2: Reset security settings for Internet Explorer 7
If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
- Click Tools, and then click Internet Options.
- Click the Security tab.
- Click Reset all zones to default level, and then click OK.
After you do this, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 3.
Note If this method does not resolve the issue, you can restore Internet Explorer 7 to its previous security level.
Method 3: Run Internet Explorer 7 in "No Add-Ons" mode
Internet Explorer 7 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 7. To determine whether the error is caused by an add-on, run Internet Explorer 7 in "No Add-Ons" mode. To do this, follow these steps:
- Click Start, and then type Internet Explorer in the Start Search box.
- Click Internet Explorer (No Add-Ons). Internet Explorer 7 opens without add-ons, toolbars, or plug-ins.
- Test Internet Explorer to verify that it works correctly. If issues still occur, try Method 4.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 7. In this case, use one of the following options.
Option 1: Reset Internet Explorer 7
loadTOCNode(3, 'moreinformation');
Reset Internet Explorer 7 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled. To reset Internet Explorer 7 settings, use Method 4.
Option 2: Use the Manage Add-ons tool to determine which add-on is causing the issue
Use the Manage Add-ons tool in Internet Explorer 7 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
- Click Tools, point to Manage Add-ons, and then click Enable or Disable Add-ons.
- In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
- For each item in this list, select the add-on, and then click Disable under Settings.
- When you have disabled all the items in this list, click OK.
- Exit and then restart Internet Explorer 7.
- If issues do not occur, repeat steps 1 through 3.
- Click Enable for a single add-on.
- Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
