It is a maytag 5 burner gas cook top 2 years old
Hello there:
A burner doesn't work
The
most common problem for gas surface burners is that they get gas but
don't light. This is generally caused by dirt or grease splatters on the
burner itself. Residential-grade range/stove burners are round and have
small holes around their perimeter to allow gas to flow out and create a
round flame. The gas coming from these holes is often ignited by a
small vertical row of holes on the side of the burner. If these vertical
holes are clogged or obstructed, the gas can't ignite.
The
solution is to clean the burners thoroughly. Use a toothpick to clear
the small vertical holes, then allow the burner to dry completely and
try lighting it again. If it doesn't light immediately, either repeat
the procedure or call a qualified appliance repair technician.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
