Cars & Trucks Logo
A
Anonymous Posted on Jun 29, 2010
I changed the alternators starter and a brand new battery something is still draining my battery down if i dont drive it for a couple of days. ???????????????
Anonymous
Level 1:
Novelist:
  • Contributor 176 Answers
  • Posted on Jul 01, 2010
Anonymous
Contributor
Level 1:
Novelist:
Answers
176
Questions
Helped
48545
Points
18
Hi my name is Tom and I can help you.
There are a number of reasons a battery gets drained. First, Is your battery capable of being charged. To determine this, take the battery to a parts store and they can tell you.
If the battery is so low it will not take a charge, you can charge it forever and it will do no good. Assuming the battery is good, check and see if any lights are on when you shut the car off. Dome and trunk lights are key spots.
My bet is the battery is too low to be charged and when you get a new battery that should be the end of your problem. I trust this information was of help to you.
Please take the time to grade my information and if I can be of further assistance please call or email me.
TomE
My battery keeps dying on my 2004 cadillac srx. changed all coils and sparkplugs.autozone check my alternator,starter and battery said it was good.
When does it die ? overnight , after a couple of days ? If it dies over night you have what is called a Parasitic drain or draw on the battery ! There is something on , a light , or a short , or one of the control modules doesn't power down . How to Test and Find Parasitic Battery Drain Key Off
1helpful
92 Saab keeps dying, won't hold charge....
You have the battery and the alternator and the alternator belt and if they are working fine there must be something that is draining the battery. You need an auto electrician to check what the drain is. In such cases,on various vehicles, the BCM, body control module, proves to have something to do with it. Get A GOOD AUTO ELECTRICIAN to check if there is a particular component
1helpful
3answers
Replaced battery. still would not start. Cleaned treminal of all corrision. cranked fine. however 1 day later would not start. jump started . drove a couple of miles but when I turned on lights, engine...
Sounds like a bad alternator. Drained your battery and when you turned on the lights it took all the power left in your battery. When you drain a battery down that far, they are real hard to jump, and coupled with the alternator, the car is not producing enough current to start and stay running.
I would take the alternator off and take it to oyur local auto parts store to be tested. If bad, replace it and charge the battery fully before starting. Then check voltage at battery with motor running. Should be 13.2 -14 Volts DC. If not, you may have a bad battery cable or blown fusible link. (especially that if the alternator tests good).....Mike
I have a 2002 VW Jetta. My battery dies after couple of days of not driving. I had a starter test done and it showed that the starter is skipping. Some one help!
check starter wiring connections must be grounded somewhere/ check also ur alternator/ battery should not drain in a few days time....
1986 Mazda 626, I was driving on the freeway when i noticed my car was losing speed when i had my foot full blown on the pedal ( I had my headphones on. no stero). I had to pull over to the side of the...
1- For the overheat, remove the thermostat to run for a few days to see the problem come back. When the engine runs at iddle, press the upper hose connecting to the radiator to see there is a water flowing inside. a- IF there is then your water pump is OK. After a few days, put back the new thermostat to run as normal. b- IF there is not then you need to replace the water pump first.
2- For your battery draining. a- IF you change only the starter, then the solenoid is the culprit, not the battery, not the alternator. b- IF you have changed both then I suspect the diode in the starter and the battery. c- To determine which one is in item b, take off negative battery cable for 2 days, - if there is no problem when hooking back then alternator diode is a culprit. - if there is a problem when hooking back then the battery is a culprit. Good luck.
2answers
1995 ford contour has new battery and won't turn over at all
sounds like your alternator isn't charging the battery.take alternator to auto parts store to have it tested.
Security system-passlock
I hav a 1995 88 w/ same problem. Key was worn out, Had Security system disabled.by installing a resistor to by pass Sec. System.Had it done for $35.00 Check locally for a starter/alternator shop in your area.
2answers
96 ford mustang gt charging problem
ignition coil not powering right
also some useful info
batterys are refurbed these days and sometimes an unlucky person can still get a dead cell battery several times even if the you bought brand new
i took mine back 4 times before i found a good one that kept its charge
dead cells dont show them selves very well on battery tests even though dead cell the tester would show good show dont think that there is something definatley wrong you could be in same ditch i was before with my batterys
alternator testers at some shops are not reliable enough i recommend a voltage tester to battery
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
