SOURCE: Canon i850 7 orange flashes =Bad printhead????
I had the same problm the printer made loud noises, the head did not move and the light flashed orange. At the right most position where the print head rests there is a gear, gunk had the gear jammed I cleaned it with a paper towel lots of black ink came out, it is working fine for a couple of days now.
SOURCE: Flashing orange lights
WASTE TANK NEEDS TO BE EMPTIED
GO ON LINE AND TYPE
CANON 850i INKJET PHOTO PRINTER 7 BLINKING LIGHT YELLOW
AND YOU CAN FIND YOUR HELP YOU NEED
ROD THE CANDYMANGNADY
SOURCE: I have a canon s9000 and am getting the following
This is indicating a defective print head.
Remove and reinstall the print head. If this does not resolve it, then you will need to look at getting a new print head.
SOURCE: Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
SOURCE: orange light blinks 7 times then green light once and repeats,
It indicate that your print head may defective probably cause by
electrical connection, u can try to unplug the print head and clean the
electrical contact part with dry paper and install it back. Make sure
the contact part is fix into the holder completely.
YBC (/\)
