Question about Dometic Rooftop RV Air Conditioner
T Tair conditioner unit in our camper runs for a
T Tair conditioner unit in our camper runs for a few minutes then trips the circut breaker........work ok on fan . any ideas
    New Friend:
  • 5 Answers
Check for proper shore amperage min 30 amp service with proper gauge power cord,Otherwise you are starving your ac and thus the kickout
Posted on Jul 02, 2010
    New Friend:
The air filter may be dirty, if thats not it it is the condinser burned up and not pumping freeon
Posted on Jun 29, 2010
SOURCE:
Compressor comes on and blows 52 degree air, but will cycle off and on every few minutes.
could be or the compresor is going off on a safety. replace run capacitor.
May 28, 2014 | Dometic 57915531 Air Conditioner
Carrier unit in camper wont come on ..dead..fuses ok..?????
Have you checked breakers in panel, to make sure one isn't tripped?
What type, year camper is this on?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
Compressor runs but fan will not. problem started a few weeks ago. would not start while it was raining. it would trip circut breaker. after a day or two of sunshine unit would start and run ok.
sounds like water is getting into the fan and one it has time to dry out its starting again check electrical connections and motor body for any signs of water damage
Jan 20, 2011 | Dometic Rooftop RV Air Conditioner
Unit turns on and hums like it wants to work but does not force air and after 3-5 minutes trips the breaker in my camper.
Most likely there is a capacitor that jump starts your air flow motor, and that capacitor is shorted and needs to be replaced. Be careful, if you don't know what you are doing, don't touch the capacitor, it has a high voltage across it.
Aug 30, 2010 | Dometic Rooftop RV Air Conditioner
I'm purchasing a generator to power the Dometic Duo Therm Brisk Air A/C unit in my camper. How many watts does it draw?
You will need at least a 5000 watt generator to run that and a few lights etc... for the camper.
heatman101
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
Have roof top air conditioner that blows air but soon trips breaker. any suggestions? Henry
check the condensor fan in the rooof unit. It's the fan blowing on the cpil on the roof.. If it failed, the head preasures can becme excessive andwork the compressor hard causing the breaker to trip. Let me know and good luck, Ned_
Sep 13, 2009 | Dometic Rooftop RV Air Conditioner
Frigidaire air conditioner/heater
You better clean that back coil quickly before you loose a compessor. Maybe ,G-- is trying to tell you something! Thank-you-very-much!
Aug 27, 2008 | Frigidaire Heating & Cooling
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Circut breakers
Is it after it has ran for a while or tripping every time it comes on? If after it runs awhile check your wire tightness at the breaker and at the unit. Loose wiring will heat up a braker and trip it. Also check to see that the rating of the unit and the breaker are matched.
Jun 05, 2008 | LG L1004R Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
223 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
