Unlock as in Jailbreak, or unlock as in Passcode unlock?
Jailbreak is you just download a third party software, such as redsnow, or blackrain, and the passcode, you just type in.
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Step 1: The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer. It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen. If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled. To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer. Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window. Click the "Restore" button. If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup. If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings. Wait while iTunes syncs with your iPod Touch and restores the device. iTunes will prompt you when this process is complete.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode. Hope it helps
If you have forgotten iPhone passcode and it resulted in failure to unlock your iPhone. You can follow below steps to unlock it with iTunes or iCloud.
-Use iCloud
(1). Open and log in iCloud on your laptop or PC that is connected with the iPod touch.
(2). Click Find My iPod and let it start to search and connect with your iPod touch APP.
(3). When iCloud is connected to the iOS device, its position will be fixed and shown on the map, then click the option at the upper right of Clear iPod and follow the next indication.
-Use recovery mode
(1). If iTunes prompts you to enter the password, and you cannot remember it, try to use the recovery mode to unlock iPod touch without password. Given that you are using recovery mode, you are not able to backup before resetting device, which means that you are going to lose all the data on the iPod touch.
(2). Close iPod device completely. Hold Power button and slide the Power Slider to close iPod touch.
(3). Connect your iPod touch to the computer and use iTunes to enter into recovery mode.
(4). Open iTunes and hold Power+Home buttons long before the logo of Apple appears. Then click Recovery Mode.
(5). Click Set Up As New iPod Touch. Initialize the settings of your iPod touch and import the backup and restore the data.
Although locking your iPod Touch prevents accidental touch commands, the feature also prevents you from accessing your media and applications while the device is locked, according to the Apple site. The lock code is the 4-digit code that was created when the passcode lock was first enabled, and displays a passcode menu prompt on the iPod Touch's screen when the "Home" or "Power" button is pressed and the unlock bar is slid across the screen.
Instructions 1 Push the "Home" button on the iPod Touch's screen, or push the "Power" button on top of the device to show the home screen. 2 Slide your finger on the iPod Touch's unlock bar. 3 Enter the 4-digit passcode using the on-screen keypad to unlock the device. If you cannot remember the passcode, plug the dock-connector cable into the iPod Touch and plug the other end into your computer's USB port. According to Apple, the iPod Touch will automatically unlock after it is connected to your computer.
The iPod touch is disabled when the incorrect unlock code is entered too many times. The time the iPod makes you wait increases each time an incorrect unlock code is entered.
There are two ways you should be able to unlock the iPod. First, connect the iPod to the computer it was last synced with. After iTunes recognizes the iPod, you should be able to enter your unlock code and unlock the iPod.
If the first method doesn't work or you don't remember your unlock code, then do this: 1) Turn the iPod off. 2) Hold down the Home button and connect the iPod to the computer it was last synced with. 3)Release the Home button when the iTunes image appears of the iPod's screen. 4)Wait for iTunes to recognize the iPod and then follow the onscreen directions to restore the iPod.
If neither method works, you will need to contact Apple Customer Support.
