SOLUTION:-
Follow these steps.
1-First of all take a usb cable.
2-Connect its one end to Bizhub 210 and the other end to your computer.
3-you will see your computer will show a notification " Found new hardware".
4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM.
5-autoplay will show at the desktop
6-Now click on "Install Printer"
7-Follow the instructions and install the drivers.
8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer.
9-Now right click on this icon and click on "Properties"
10-now click on "PRINTING PREFERENCES" tab.
11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list.
12-now give a print command.ctrl+p. of any document.
13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken.
if there is any other printers are installed on your computer which are not in use then remove them/ delete them.
use konica minolta bizhub 210 as a default printer.
