Konica Minolta bizhub 161f All-In-One Laser Printer Logo
Posted on Jun 28, 2010
I have message call service(M1) So how to clear? When I press Utility and then stop, 0,0, stop, 0,1 , nothing hepened... Please,Please,Please help me to solve this problem!!!
Vishal Dugg
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2017
Vishal Dugg
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
5123
Points
Firstly press menu then press quick setting then twoo time press left arrow then again press quick setting then press left aroow and after this press right arrow service mode will open at ur machine select "Maintenance Counter" now in this option select, 0 and press ok.
1 Related Answer
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 21, 2010
SOURCE: I have message call service(M1) So how to clear
go to service mode, press utility button from the panel, now press " stop, 0,0, stop, 0,1, it will show service mode, now select shipment, in this option, select "Maintenance Counter" now in this option select, 0 and press ok.
How to clear error in Monika Minolta bizhub 185e maintenance call (m2) call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
How to clear on shown display in konica minolta maintenance call m2 call service
Konica minolta bizhub 215 showing maintenance call(m2) and service callProcedure1. Press the COUNTER. (UTILITY)2. Press the following keys in this order:STOP 0 0 STOP 0 13. Enter the code number corresponding to the function to be used from theKEYPAD.4. Press the START.< Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply countthen ok to clear. On/ Off the machine it will work as usual.
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to reset M1 call service on bizhub 250?
Go to service mode, press utility button from the panel, now press " stop, 0,0, stop, 0,1, it will show service mode, now select shipment, in this option, select "Maintenance Counter" now in this option select, 0 and press ok.
4helpful
What is solution for konicaminolta 164 maitanance call m2
Code M1 bizhub162
Press the Utility key
Stop 0 0 Stop 0 1
The Service mode menu screen will appear.
Select the 11. CLEAR DATA
MAINTENANCE COUNTER
Select the setting value using the 10-Key Pad.
Validate the selection by pressing the [Yes] key.
5helpful
5answers
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
3helpful
6answers
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
28helpful
I have message call service(M1) So how to clear this problem
14helpful
3answers
Error message M1
Press Utility / Counter -> {STOP}{0}{0}{STOP}{0}{1}, now you should be in Service Mode. Go to Service Choice - > IU LIFE STOP MODE -> and choose CONTINUOUS.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
