SOURCE: Memory card locked
its a tab on the memory card that needs to be slid to the opposite position
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
you have to put a bit of tape around the bit were the little tab use to be.. This works epically if you have lost the tab from the card.
p.s. i did this with an SD card an it worked i don't know if it will work with any other types of card. good luck anywhos, try yahoo answers they seem to have alot of info too. (Y)
SOURCE: CARD LOCKED
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock
and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
Hi...I have a Canon Digital Camera (Power shot a640),i got a message that says card locked
I need an assistance iunlocling the card
