That's common with most depth finders ..there not to run at a high speed and read the bottom havent found one yet that will do that unit should read the bottom at a slow speed ..at high speed it will lose what they call ( bottom lock ) unit will not read then . . .once bottom lock is returned it will start to read then
What you are experiencing sounds like air bubbles crossing the face of the transducer. If you have a transom mount transducer check the face of the transducer. Make sure that it is clean. Also make sure the front of the transducer is a tiny bit lower than the back. The digital readout on the screen will only happen when you have a strong signal of the bottom.
